longprong opened this issue on May 04, 2014 · 4 posts
longprong posted Sun, 04 May 2014 at 2:57 PM
Can somebody please explain why my render has distorted everything - the props, table etc have produced bulbous surfaces etc and the figure has produced minor poke through not present in the preview
Thanks for any advice
vilters posted Sun, 04 May 2014 at 3:18 PM
Smooth Polygons.
You enabled "Smooth Polygons" in the render settings.
This works in combination witht the crease angle that you can set in each group in the groups properties.
Disable Smooth Polygons in the renders ettings.
Or uncheck the option "Smooth polygons" in the groups that you do not want smoothed.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
longprong posted Sun, 04 May 2014 at 3:21 PM
Thanks Vilters...knew there was a simple solution to this :)
aldebaran40 posted Sun, 04 May 2014 at 3:36 PM
I can be wrong but you may want to turn off Smoothing on the tables and props . That way you will not get the "Poser Bloat" that you see there. That will allow you to use smoothing in the render settings. Just choose the prop, click on Properties and uncheck "Smooth polygons". I hope it's help you
ps.vilters was more fast ...
