Subject: Right click freezes Library window
ElZagna opened this issue on Jun 02, 2014 · 13 posts
ElZagna posted Mon, 02 June 2014 at 11:06 PM
I recently noticed that when I right click inside the Library window the Library windows freezes. I can move the window around, and close and reopen it but nothing inside the window is accessable. Sometimes it unhangs after 20 or 30 seconds but sometimes I have to close Poser and reopen.
I've submitted an incident report to SM, but does anyone else have this problem?
OS: Windows 10 64-bit, Poser: 10
hborre posted Tue, 03 June 2014 at 8:36 AM
Haven't seen anything unusual in PP2014 32-bit; are you current with all the SRs?  And has anything changed or updated recently?
ElZagna posted Tue, 03 June 2014 at 10:28 AM
I recently upgraded from Windows Vista to 8.1, which required me to install some Poser 9 upgrades, but everything should be current.
honzu posted Tue, 03 June 2014 at 2:30 PM
Same freezing here. PPro2014 64bit / W7 64bit
Alt-Tab to another program and switching back solves the freeze sometimes
Vaskania posted Tue, 03 June 2014 at 2:46 PM
Are you using the internal or external library? Try switching to the other in the preferences.
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
ElZagna posted Tue, 03 June 2014 at 3:27 PM
Hmmm... Yep, it looks like just going to another app will unfreeze it.
Vaskania, what internal and external libraries are you talking about? Do you mean the Poser default library?
Vaskania posted Tue, 03 June 2014 at 5:31 PM
Yes. Poser's library can run on two modes.. internal (flash based.. or IE.. I forget) and external (adobe air based). Sometimes if you have issues with one, switching to the other may help.
Edit > General Preferences > Library tab.
Just note that external mode can't be docked and is used as a second window.
-----sig-----
hborre posted Tue, 03 June 2014 at 6:27 PM
Adobe Flash does not work well in 64-bit, use Adobe Air instead for the Library.
ElZagna posted Tue, 03 June 2014 at 8:23 PM
I am running Poser 9 in Windows 8.1 32-bit. The two modes aren't an option for me.
Vaskania posted Wed, 04 June 2014 at 4:16 AM
Take a read through this thread: http://forum.runtimedna.com/showthread.php?85917-External-Library-for-Poser-Pro-2012
The user was also experiencing issues with Windows 8 and the Poser library.
-----sig-----
hborre posted Wed, 04 June 2014 at 9:27 AM
Quote - I am running Poser 9 in Windows 8.1 32-bit. The two modes aren't an option for me.
Oops!  Entirely missed that point.
ElZagna posted Wed, 04 June 2014 at 10:00 AM
Quote - Same freezing here. PPro2014 64bit / W7 64bit
Since you have Poer Pro, have you tried the suggestions about using the external (Air) library?
honzu posted Wed, 04 June 2014 at 12:03 PM
yes, that "fixed" it.
