Subject: Main work window disapeared PoserPro2010
mouser opened this issue on Jun 09, 2014 · 6 posts
mouser posted Mon, 09 June 2014 at 12:47 AM
While the Library panel and the render window apears my main work window has disapeared of the face of the earth.
No error messages, nothing?
The render window still contains my last file and still renders okay but wihtout thte main window I cant do any work.
Anyone else run into this?
Posrerpro2010 plus updates
Win7 (64bit)
i7
6 gig ram
ironsoul posted Mon, 09 June 2014 at 1:16 AM
This is the preview window?
Do you get the preview tab at the top next to the Render tab or just the Render tab.
One thought is maybe an OpenGL problem, have you tried switching to SreeD (menu Display->Preview Drawing)
Teyon posted Mon, 09 June 2014 at 1:58 AM
Attached Link: Solving weird issues with Poser by removing the preferences
If Poser crashes or starts behaving oddly for no apparent reason, it may be that its preference files have been damaged or corrupted. Removing the damaged files will restore Poser to its factory default settings and may fix problems that won't go away otherwise. This won't remove any additional figures, props or poses that you might have installed.
Have a look at the link attached to learn how to delete your poser preferences.
mouser posted Mon, 09 June 2014 at 2:23 AM
No, the window with the tabs Preview and Render is still there plus the Poser Library panel.
Its the main Poser window that has the editing tools, Camera controls, light controls, Plus all of the tabs (Pose, Material, Face, Hair, Cloth, setup & content) etc that has disapered.
I'm used to the library going walkabout but not the main work screen?
There was no crash, error messages or dump files?
mouser posted Mon, 09 June 2014 at 3:43 AM
Amazing what a full reboot will do, its back.
ironsoul posted Mon, 09 June 2014 at 11:33 AM
Doh, maybe I should have just posted a photo of the tee-shirt I'm wearing at the moment - it says "have you tried turning it off and on again". Good you found a solution.
