Batsarse opened this issue on Jun 09, 2014 · 4 posts
Batsarse posted Mon, 09 June 2014 at 5:06 AM
I'm using Windows 7 64-bit, on an Intel i7 2.67GHz CPU and an NVidia GeForce GTX660 graphics card.
The screenshot included should hopefully make it clear what I'm up against. Any advice or recommendations would be gratefully received.
cspear posted Mon, 09 June 2014 at 5:09 AM
The one in the box probably isn't the latest version. You need to update.
PoserPro 11 - Units: Metres
Adobe CC 2017
aRtBee posted Mon, 09 June 2014 at 5:27 AM
the docked one - which you're showing, requires Flash. Since you're using Poser (a 32bit program) in a 64-bit Windows environment, you might need the 32-bit Flash as well.
the undocked / external window one requires Air, this can be set for in Preferences. Same 32/64bit story then. But I'm not sure if that's Poser Pro only.
Perhaps this helps, my 2ct. And indeed, get the latest SR available.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
Batsarse posted Mon, 09 June 2014 at 7:12 AM
Thank-you, everyone. It's working now :)
