Forum: DAZ|Studio
Subject: Using Auto-Fit - Genesis to Genesis 2 Male Tutorial
cedarwolf opened this issue on Jun 10, 2014 · 4 posts
cedarwolf posted Tue, 10 June 2014 at 2:03 PM
Where the heck is it?  It was downloaded and installed but no trace was left as to where to locate it or how to use the .dsa file.
Please?
manleystanley posted Tue, 10 June 2014 at 2:43 PM
Tutorial?
Load G2M, go to the genesis folder, select/load the clothes.
Select the clothes in the scene tab, general tab{right side}, fit to, genesis, select a clothing type. Done.
I'd do screen caps but I'm not sure which interface you may be using so they could be confusing.
Unless you are having issues with an artical of clotheing, then we'd need more info
And thanks, I don't use G2F/M much becaise that aren't real carrara compatable, but till I checked for this thread I didn't know there was a full length rode setting for autofit for G2M
DustRider posted Tue, 10 June 2014 at 4:56 PM
I'm not at my computer right now, but as I recall, down on the lower right hand side of the screen when you start up DS there is a small drop down called "Select Lesson", click on it and you should see your newly installed tutorial(s) in the list (if I'm correct in guessing that you mean the recent free tutotials that DAZ had).
Hope this helps!
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
cedarwolf posted Tue, 10 June 2014 at 6:12 PM
Thanks everyone.  Quite literally, after an hour I finally reset my view and low and behold!  Down on the bottom right side was this "tutorials" thing.  After carefully poking it a few times, I found the OTHER tutorials!  Now I just have to schedule the time to work through them.
Again, thanks folks.
