Forum: Vue
Subject: UVMaps messed up when importing Poser figure to Vu
NanetteTredoux opened this issue on Jun 16, 2014 · 5 posts
NanetteTredoux posted Mon, 16 June 2014 at 11:25 AM
I imported Victoria 3 to Vue. She had EZskin shaders applied. I chose not to use Poser shaders. This is what the preview looked like in Vue:
Poser 11 Pro, Windows 10
NanetteTredoux posted Mon, 16 June 2014 at 11:26 AM
This is what it looked like rendered:
NanetteTredoux posted Mon, 16 June 2014 at 11:27 AM
This is what V3 looks like rendered in Vue with no Subsurface scattering materials applied:
lam2 posted Mon, 16 June 2014 at 1:55 PM
Mmm, I tried the same thing you did.
Applying EZskin to v3 and save it to pz3, and import it into Vue.
As usual, I don't use Poser shader tree, and since I don't use it, Vue would ignore all the SSS info., so it should not affect the UV map at all I think.
When I rendered the v3 as you did, it rendered fine.
Whether or not I use EZskin, it didn't make any difference in Vue.
...just a little more info.
NanetteTredoux posted Mon, 16 June 2014 at 11:33 PM
I am baffled. I was not using the Poser shader tree. I should try this with some other figures as well. It happens with Maddie too, the distortion in the mapping looks the same. They are both Daz Gen 3 figures and use the same mapping.
