wealthychef opened this issue on Jun 30, 2014 · 8 posts
wealthychef posted Mon, 30 June 2014 at 9:53 PM
Lobo3433 posted Mon, 30 June 2014 at 10:09 PM Forum Moderator
While in the node editor click on add and their is a background node you can add but it might not show up in 2.70 I know in 2.71 I had to click add and scroll down to search "background" and enter and it adds the background node. I still a novice with cycles myself but that was the quickest answer I could find at the moment if that does not help I am confident another of our forum members will chime in if they have a better answer.
Good Luck
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Blender 3D Facebook Page
wealthychef posted Tue, 01 July 2014 at 11:27 AM
wealthychef posted Tue, 01 July 2014 at 1:33 PM
However, this does NOT tile the image. Anyone know how I can tile the image acroos the background instead of having a huge image?
heddheld posted Tue, 01 July 2014 at 3:51 PM
enviroment tex is "usualy" an hdr (dosnt have to be ) so wouldn't really be tilable
could try adding a mapping node then scale it from there , never tried that so not 100% it would work
or could load a plane and add your tile to that just have to get scales/angles right for cam view
pauljs75 posted Wed, 02 July 2014 at 6:29 AM
Quote - Anyone know how I can tile the image acroos the background instead of having a huge image?
Input>Texture Coordinate (Generated, Window, or Camera) plugged into Vector>Mapping, which is then plugged into the vector socket on your image texture. X and Y scaling settings should do the job. Other adjustments of interest are Z-rotation and X and Y location.
wealthychef posted Sat, 05 July 2014 at 12:35 PM
Quote - Input>Texture Coordinate (Generated, Window, or Camera) plugged into Vector>Mapping, which is then plugged into the vector socket on your image texture. X and Y scaling settings should do the job. Other adjustments of interest are Z-rotation and X and Y location.
Sounds excellent, I'll try that too. What is working very well in my case now was to create a hexahedron (anisotropically scaled cube) around my scene and texture an image onto it. Gives exactly the effect I want for my project.
kyraia posted Tue, 22 July 2014 at 6:13 AM
try this (in Blender 2.71): World -> Surface: Background, Color: Environment Texture
I took a landscape from cgtextures.com in the example (which is unfortunately not tiled so what you see depends on the view angle).
Note: the background is only visible in rendered preview!
Kyraia
