Boni opened this issue on Jun 30, 2014 · 61 posts
Boni posted Mon, 30 June 2014 at 10:28 PM
I just ordered pp2014, upgradingfrom pp2010. I just watched the sm webinar covering sss, butthey didm't cover eyes. Iwould like to know how to make good sss eyes in 2014.
Thanks in advance.
Boni
Boni
cspear posted Tue, 01 July 2014 at 7:43 AM
Use SnarlyGribbly's EZ-Skin
I'm not convinced SSS on eyes is needed for anything other than close-ups
PoserPro 11 - Units: Metres
Adobe CC 2017
Boni posted Tue, 01 July 2014 at 8:35 AM
Agreed, but I am looking for instructions, rather than a prepackaged product. Any tutorials out there?
Boni
vilters posted Tue, 01 July 2014 at 9:04 AM
Eyes are special.
The eyeball, the iris, the pupil, the cornea, all need to be looked into, and all attribute to the final result, and some will certainly interfere with each other.
Do all need SSS?
Be certain to put them all in different SSS groups or you can get some nasty blue artifacts.
Have not seen a tut on the subject yet.
I think BB had en eye setup on his site. You could check there and build from there on?
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
bagginsbill posted Tue, 01 July 2014 at 9:17 AM
I have not posted an eye setup on my site.
I have in various threads, but I have problems with a generic solution.
Different figures have wildly different arrangements. (Eyesurface that overlaps everything and includes cornea, eyesurface that overlaps everything as well as a separate cornea surface, no eyesurface just a cornea, etc.)
The luminance level on the sclera is wildly different on one texture set versus another, so tuning to match what real eyes look like is always an exercise on your part which requires that you fully understand how to build and tune a shader.
People differ on whether they intend to go for max realism or they just want quick and dirty and they're willing or even enthusiastic to use textures with burned-in highlights. These look incredibly stupid when you use scatter and real reflections.
People do not pay attention to the environmental factors - your light source(s) had better be tuned for realism (use my light meter first) and if you want good looking reflections based on realistic reflection values (Fresnel!), you need HDRI imaging or real props that glow at HDR levels. (Much greater than 1)
Poser transparency lets light through a cornea/surface onto the iris. Poser refraction does not. Realism requires refraction. Therefore you get little or no light on the iris. Compensations require understanding how to self-light the iris just enough to deal with this. Or require crafting a cornea as a separate actor (as I did with the BB eye) so that you can turn off shadow casting on from the cornea.
Boni posted Tue, 01 July 2014 at 12:12 PM
Wow, this is exactly what I'm looking for. I do understand some of the challenges involved ... but believe that the result would be worth it. Primarily I will be workingiwth V4 ... but knowing that I'd have to approach different figures differently helps a lot.
After reading over your list BB, (may I call you BB?) I was caught by the problem of Transparency and refraction ... and self illumination for the iris. Since I'm upgrading from PP2010 to PP2014 I haven't had the pleasure of working with self illumination yet. Would this be a workable solution if worked with subtly?
Also since the environment plays such a strong factor in this ... finding a "master" shading system for each figure to use in well orginized scenes, using good environmental spheres such as yours could be counter productive? That is each shader must be created to fit a particular scene ... or could a master be made that could be used in any scene as long as the scene is set up well?
Vilters: you have braught up some good questions too. I'm definately bookmarking this thread!
Boni
Boni
Miss Nancy posted Tue, 01 July 2014 at 1:51 PM
in re: 4, didn't they fix refraction shadow-casting yet?
bagginsbill posted Tue, 01 July 2014 at 2:51 PM
Quote - in re: 4, didn't they fix refraction shadow-casting yet?
No and I reopened the bug report on the bend angle - turns out it isn't done right.
Miss Nancy posted Tue, 01 July 2014 at 5:01 PM
also in re: 4, have noticed reflected scenes usually too dark, and apparently it isn't user error.
Boni posted Wed, 02 July 2014 at 5:33 PM
I have another question. Why is it with most poser renders that the shadow of the lid and lashes never come down over the upper portion of the eye as it does in "real life"? It's an effect I've tried to figure out for a long time.
Thanks
Boni
Boni
Miss Nancy posted Wed, 02 July 2014 at 6:19 PM
they may use shadow-mapped lites, low pixel samples or high shading rate. they may also turn off shadows, like they do for transmapped hair.
bagginsbill posted Fri, 11 July 2014 at 1:47 PM
Sorry I was gone so long. I am in the middle of developing VSS Pro and I wanted to use it while working on these settings, since it is so much easier to make multi-material changes with a single click in VSS.
So I have done some experiments and I'll show you some techniques on how to set up eye shaders on V4.
bagginsbill posted Fri, 11 July 2014 at 1:49 PM
First - sun and sky (one infinite light, cloudy sky EnvSphere).
bagginsbill posted Fri, 11 July 2014 at 1:50 PM
bagginsbill posted Fri, 11 July 2014 at 1:51 PM
bagginsbill posted Fri, 11 July 2014 at 1:52 PM
bagginsbill posted Fri, 11 July 2014 at 1:53 PM
bagginsbill posted Fri, 11 July 2014 at 1:57 PM
The cornea (seen here in magenta) covers only the iris.
bagginsbill posted Fri, 11 July 2014 at 2:00 PM
bagginsbill posted Fri, 11 July 2014 at 2:01 PM
bagginsbill posted Fri, 11 July 2014 at 2:05 PM
My suggestions:
Use the Cornea and Sclera to make reflections. Make the EyeSurface invisible.
Use the EyeSurface to make reflections. Make the Cornea invisible.
Option 1 gives the best results as you can apply procedural bump to the sclera and refraction to the cornea and get a very realistic looking eye. But you only notice the incremental benefit up close, and there are some gotchas to it that make it more work.
Option 2 is less work and gives good results. I did option 2 in all those images, so it's pretty good.
So - either way you need to make something invisible. This is the shader to do it.
It is 100% transparent in all directions.
aRtBee posted Fri, 11 July 2014 at 2:24 PM
BB, looks promising, but...
in photography, one usually sets the camera focus to the eye(s), so these are "tack sharp" in any image whatever the camera DoF set.
But in the images above, the facial skin appears quite sharp while the eyes make a blurred and watered impression to me. I see a difference, in my opinion it's too much, and the wrong way around. She seems just to start/stop crying to me.
Hope this gets improved upon.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
bagginsbill posted Fri, 11 July 2014 at 2:29 PM
The Reflect node gives us reflections from objects. (including the EnvSphere)
The Blinn node gives us reflections from Poser lights. Lights are a fiction - they're not really there. They have no size.
The Blinn eccentricity affects the apparent size of the light source as well as the apparent blurriness of the object. It has to be matched to the Reflect node's softness. But not literally matched - the two values have very different interpretations.
In my shader work, I express the "blur" of a surface with the word "blur". Blur can be 0, .1, .5, .75737, 1, 1.5, 2, 5, etc. Above 5, Poser's Reflect node softness really breaks down and doesn't work, so watch out for that.
To translate blur to Reflect and Blinn nodes, I use the following rules:
Reflect.softness = blur <--- that was easy!
Blinn.eccentricity = .03 + .065 * blur
In this shader, I used a blur of .1, and so that is how the values got there.
The Blinn node also has its own built-in sort-of Fresnel effect (SpecularRollOff), which I turn off (set to 1 = no falloff) because I intend to always modulate reflections with a Fresnel_Blend node.
The Blinn Reflectivity controls its brightness. This is a "relative" term. If you try to understand this Reflectivity deeply, you will probably fail and we'll have to have a very long conversation about this one parameter and how Poser's unitless light system is kind of a pain.
Short answer, is I use this formula
Blinn.Reflectivity = 90 * (.5 ** blur)
That's 1/2 raised to a number equal to my chosen blur. In this case, with blur = .1, that comes to 83.973. (I did not type this - VSS built it.)
The Reflect Quality parameter is very fussy to deal with. As a rule of thumb, for curved things it can be under .5 with moderate blur. If your blur is 0, it can be .1. VSS generates appropriate values based on the blur. For eyes which really don't need blur at all, you could speed them up by removing the blur (blur = 0) and set the Quality to .1.
I don't want to talk about RayBias. It's complicated. I left it at its default for now.
bagginsbill posted Fri, 11 July 2014 at 2:49 PM
Quote - But in the images above, the facial skin appears quite sharp while the eyes make a blurred and watered impression to me. I see a difference, in my opinion it's too much, and the wrong way around. She seems just to start/stop crying to me.
Are you talking about the iris and sclera texture (color maps) or the reflections?
The color maps are a little blurry in and of themselves, and then the Scatter node smears them some more. This is adjustable. I didn't attend to it.
But I don't know if that's what you're referring to.
Miss Nancy posted Fri, 11 July 2014 at 2:56 PM
thx fr great eye discussion! they don't look blurry on my monitor.
bagginsbill posted Fri, 11 July 2014 at 3:12 PM
This is with the blur set to .1. The reflections look sharp to me.
I don't use blur = 0 very often, because I like to use pretty crappy min shading rate for speed, and so you sometimes see jaggies in reflections. By softening reflections a bit, those jaggies go away. This saves me having to use costly low MSR for the whole scene.
A blur of .1 is not enough to smear reflections on a curved surface - but just enough to hide pixellation artifacts.
Now, being that we're up close here, the unnatural smoothness of the sclera is revealed. A closeup requires that you no use EyeSurface, but rather you set up cornea and sclera for the reflections. We'll get to that later.
bagginsbill posted Fri, 11 July 2014 at 3:17 PM
If you don't like the tear at all (many people don't) then use the invisible shader on it instead.
For artistic reasons, I increased the IOR to 1.4 - this gives slightly more obvious reflections without being ridiculous. The actual IOR of water is 1.33. I assume tears are close to that, but perhaps salt increases the IOR? In which case, my 1.4 is probably dead on.
We also possibly have a thin-film effect bouncing light between cornea and water surface, which may increase the reflection amount. So it's sensible to go higher if you like.
If you love glassy shiny eyes, go way higher - try 1.5 or 1.6. (Glass is 1.54) If you go above 1.6 it looks crazy like silicon eyes. Don't do that.
The way this is working is that the Fresnel_Blend node gives us a proportion for how much light is reflected. The complement of that is refracted. It turns out that when you plug something into Transparency, the value is assumed to be an opacity which is multiplied with other things - in particular with Alternate_Diffuse. The complement of what is plugged in is transmitted.
Voila !
Note: My node names are sometimes adding or removing _ - this is because VSS generated them. Learn your nodes and the _ will never bother your understanding.
bagginsbill posted Fri, 11 July 2014 at 3:28 PM
It's basically color map -> scatter.
However, I like to adjust. I always enjoy having an HSV node after my color map so I can tweak. Here I tinted it yellow (because I felt the color map was too blue). I also made it brighter (Value = 1.5). You can adjust saturation as well, but I didn't need to here.
I also have an HSV after the scatter. This is because I found it best to boost the input to scatter and then suppress the output. I can't tell you why this helps, but it does. I generally leave that .8 Value no matter what.
So the chain is color map -> HSV -> scatter -> HSV.
The bump part is optional. The texture set I loaded had a bump map here. If you're going to use the bump map, do it right.
Make it linear - set its gamma = 1
Subtract .5 so that gray is "no change".
bagginsbill posted Fri, 11 July 2014 at 3:31 PM
However - the node values here are NOT the same. I wanted the somewhat weak blue iris texture to be more exciting. So I boosted both saturation and value. And I didn't need the yellow tint.
I forgot to mention earlier - your eye scatters need to be in a different scatter group than your skin scatter. Assuming your skin is group 1, set the eye scatters to 2 as I've done here.
If you don't remember to make a different scatter group, then the skin will look blue around the eyeballs.
bagginsbill posted Fri, 11 July 2014 at 3:55 PM
Use the "invisible" shader on EyeSurface
Use the "smooth reflection" shader on Cornea.
Use this on Sclera.
This shader is basically BBGlossy in modern form using all the features of the current Poser.
Note: This bump map is crap. First of all it's derived from the color map, so the dark arteries become indentations. I had to invert the bump value to -.03 inches to flip the depressions into ridges. You probably want to use a good bump map and won't need to flip the sign on the bump. Or - perhaps we should (as I so often do) discard the bump map and use a procedural bump. Hmmm - I will try that in a bit.
bagginsbill posted Fri, 11 July 2014 at 3:58 PM
bagginsbill posted Fri, 11 July 2014 at 4:08 PM
bagginsbill posted Fri, 11 July 2014 at 4:10 PM
bagginsbill posted Fri, 11 July 2014 at 4:21 PM
I actually increased the maximum value on the morphs and used 2.
Here they are set to 1.
The morphs are:
EyeCorneaBulge
EyeIrisConvexity
bagginsbill posted Fri, 11 July 2014 at 4:40 PM
Here's the refracting cornea material.
bagginsbill posted Fri, 11 July 2014 at 4:42 PM
This requires you to decide how much to light them.
In the shader, you grab the HSV coming off the color map and plug it into Ambiet_Color. Set the Ambient_Value as you like. I used .5 here.
bagginsbill posted Fri, 11 July 2014 at 4:43 PM
bagginsbill posted Fri, 11 July 2014 at 4:47 PM
Enjoy!
Show me your work.
(Note: I saw after posting this that I had her neck twisted in a weird pose - ignore that please.)
bagginsbill posted Fri, 11 July 2014 at 4:52 PM
With the refracting cornea, you can run into one of Poser's weird problems. The ray bias will allow you to skip the iris. Any surface that is closer than the ray bias distance is ignored by the refract or reflect nodes.
On some figures you can't make this go away. Others you can adjust (decrease) the refract ray bias and make it work.
I thought the ring around the cornea here was the ray bias but it's actually because I changed the head angle. Now the lighting is different and the iris glow is too strong.
That's why you do not want to use glow. It's a pain in the butt.
Latexluv posted Fri, 11 July 2014 at 6:12 PM
Weapons of choice:
bagginsbill posted Fri, 11 July 2014 at 6:19 PM
Quote - I gave it a whirl.
I like it!
Something I noticed - the sclera has an obvious symmetrical red spot below and outside the iris, and the left and right iris appear identical too. Did you make the texture? If so, mix those up a little.
If you bought it - then tell the vendor not to be so lazy. Draw two eyes.
Latexluv posted Fri, 11 July 2014 at 6:45 PM
Weapons of choice:
aRtBee posted Mon, 14 July 2014 at 5:42 AM
In the meantime, let me come back to my statement that "in the render, the eyes made a weaker (less sharp, ...) impression that the facial skin" or something alike.
So I made a comparison with some photographs from the galleries - BBs render is in the middle. Postwork on all: rotation to set the eyes horizontally, scaling to align the pupils amongst all images, slight levels adjustment so all have the same black/white points.
My impression:
So the relative difference between eyes and skin as I flagged earlier still stands, but it's not in the eyes but in the skin instead, and IMO that's something to bear in mind when overall photorealsm is of interest.
MistyLaraCarrara posted Mon, 14 July 2014 at 5:27 PM
Homework! :wub:
using pp12, though.
bagginsbill posted Mon, 14 July 2014 at 7:16 PM
Well you showed a bunch of glamour photos which look like they involve makeup, postwork blemish removal, and extra bright lighting. I rendered the freckled uncovered skin of an Irish woman in natural light (mostly).
But I can change it quite a bit while still using the same textures and same node setup - just different numbers. There's a lot you can do with shaders and lighting.
Believable3D posted Mon, 14 July 2014 at 11:09 PM
Honestly, I suspect the real issue at this point is that the eye texture itself is just slightly less than believable and it's throwing off the realism.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
hornet3d posted Tue, 15 July 2014 at 5:32 AM
Quote - Honestly, I suspect the real issue at this point is that the eye texture itself is just slightly less than believable and it's throwing off the realism.
I think there is a lot of truth in that and the pictures ealier were not only glamour shoots but also not high quality and a couple look as though soft focus was used. I can see the point trying to be made here but not sure on the strength of the examples.
The other point is that the OP was looking for the best SSS technique for eyes and, having followed this thread and played with my favorite character this has to be the best setup I have seen for believeable reflections. I am still playing with the parameters as I like the eyes to be a little sharper than I have at present. This may also be a factor of the texture but lets be honest here, this is a long way from the eyes currently suppled with many characters. I mean finding a character with the option for real reflections is a bonus, most I have seen come with reflections burnt in making the textures a complete non strater in this context.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
bagginsbill posted Tue, 15 July 2014 at 7:24 AM
bagginsbill posted Tue, 15 July 2014 at 6:07 PM
These are the standard texture maps, but obviously I replaced the shaders.
The morphs are mostly the built-in dials. I had to do a nose job using a magnet, since no suitable morph would make the middle part narrower.
The forum is slightly shrinking the image. Click for full size to see the detail.
Miss Nancy posted Tue, 15 July 2014 at 6:29 PM
she's irish? it looks like pepper potts. looks great with hair!
hornet3d posted Wed, 16 July 2014 at 5:20 AM
Wow, love the render of Alyson2.
Well this is my attempt. Reflection is mainly the lighting of the room which has light panels in the ceiling and lower part of the walls but there is also some reflection from a display panel as well.
Glen posted Mon, 21 July 2014 at 10:53 PM
Quote - she's irish? it looks like pepper potts. looks great with hair!
Dublin from Danae I think. Danae's skin mats look so good.
I must say, Bagginsbill, you've given me yet more stuff to do to Annie, lol! I'm going to end up making all new maps for her anyway, so this is really good stuff to learn. Some of these results are awesome!
I must say though, all this attention on the eyeballs is great and all, but if we're going to get them to this level, perhaps (especially in V4's case) we should look at making the lashes better... just, y'know, saying! ;)
Bookmarked the thread for future reference. Thank you all! :)
I'm running Win 10 Pro 32GB RAM Intel Core i7-4790K CPU @ 4.00GHz Nvidia GeForce GTX 1660 Ti
My DA Gallery: glen85.deviantart.com/gallery
Peace, love and polygons!
MistyLaraCarrara posted Sun, 09 November 2014 at 1:00 PM
is the open claw eyes uvmap advantageous over the sphere style?
Boni posted Wed, 26 November 2014 at 8:35 AM
IF I use the eye surface for reflection how do I get the bump/displacement on the sclera and not on the cornea?
Boni
bagginsbill posted Sat, 18 April 2015 at 7:36 AM
I'm sorry for not answering. This post was soon after the site software changed, and notifications of replies stopped being sent. I'm not sure what you mean so I can't answer. However, I will point out that V4's eye, with the discontinuity between sclera and iris, is a big problem. The iris edge is always too sharp.
bagginsbill posted Sat, 18 April 2015 at 7:37 AM
You would need to find or make a UV-mapped mask image that distinguishes between those two areas (one white, the other black) and then you'd use that to control the amount of bump by multiplying (plug in) this mask (white where you want bump and black where you don't) with the bump value. If the mask is the other way around, then you would invert it first using a math:Subtract node (1 - map)
DeathMetalDesk posted Sat, 18 April 2015 at 8:21 AM
The open claw style map is where the sphere is cut at the back with a cross shaped cut (as you'll see in the V4 sclera uv) to unfold, producing a vaguely X shaped map. Sphere style is usually produced when a hemisphere style geometry is mapped with a planar normal style mapping, as seen on the V4 eyesurface uv. I've found that the claw style mapping is better at reducing distortions toward the back of the uv area and has a better range of distortion free horizontal image area for texturing. The sphere style is used often when visible area of the uv is of lesser importance. Self explanatory considering the above why V4's eye uv's were mapped the way they were, although I think that whoever did the mapping perhaps went overboard in fiddling with the maps in terms of end user friendliness (perhaps so with the geometry also).
bagginsbill posted Sat, 18 April 2015 at 11:22 AM
I've never rendered the back of an eyeball - why would it even matter how that is UV mapped (the back) ?
DeathMetalDesk posted Sat, 18 April 2015 at 2:36 PM
Neatness sake on the part of the modeler, I'd say. Just one of those fussy things. Who can say what purpose a model will be put to? I see that your bbeye is 2 hemispheres with a planar style mapping... I predict you will say "what difference does that make?"
Subjectively none I guess, but... apply a checkerboard pattern image map to the 'eye' prop and note all of the stretching going on in the uv's. Now apply the same patterned image map to V4's various eyeball materials and you'll perhaps realize why the modeler mapped her eye the way he did. It's assumed by most modelers during uving that an attempt should be made to provide the best uv's for image maps to be applied to. Shader considerations are usually a matter of speculation on the part of modelers. As you well know.
DeathMetalDesk posted Sat, 18 April 2015 at 2:53 PM
Not saying that V4's eyes are mapped or made better than bbeye at all... it's a matter of purposes I guess. Ideally a hybrid of both methods would be best IMHO. bbeye has the cornea built in to the cover, which I feel is superior. V4's eyeball mesh is a closed object which I feel is better considering extreme range of rotations. From a texturing/image map perspective I'm on the fence about the handling of pupil and iris in either... Leaning more toward including the uv's altogether as you've done with bbeye but wish that it were a closed mesh unfolded at the back.
Miss Nancy posted Mon, 01 June 2015 at 5:06 PM
I'm guessing your refracting-transmitting shader won't help, as iris still too close to cornea.
