Forum: Blender
Subject: Blender python: Creating a cylinder given two endpoints and a radius
wealthychef opened this issue on Jul 07, 2014 · 3 posts
wealthychef posted Mon, 07 July 2014 at 10:40 PM
I am stuck trying to make a cylinder given its endpoint locations and a radius.  I need to compute the rotation for the following function call:
bpy.ops.mesh.primitive_cylinder_add(radius = radius, depth = depth, location = center, rotation = rotation)
How do I do this?  For example, given endpoints (0,0,0) and (2,2,2), what value do I use for "rotation"?  Thanks for any pointers.
wealthychef posted Tue, 08 July 2014 at 8:12 PM
Tough one, eh?  :-)  I've googled all over the place, and I've found some code, but it does not work. that is, the resulting quaternion, when used as obj.rotate_quaternion, does not result in properly rotated cylinder with ep1 = (0,0,0) and ep1 = (0,100,0)
def FindRotation(ep1, ep2):
First, create quaternion per
http://stackoverflow.com/questions/1171849/finding-quaternion-representing-the-rotation-from-one-vector-to-another
vec = numpy.array(ep2) - numpy.array(ep1)
vec = vec/numpy.linalg.norm(vec)
if not vec[0] and not vec[1]:
return (0,0,0)
print ("vec: %s"%str(vec))
Z = numpy.array((0,0,1))
kcostheta = numpy.dot(Z, vec)
k = Length(vec) # sqrt(Length(vec)^2 * Length(Z)^2) = Length(vec)
Q = Quaternion(numpy.cross(vec,Z), kcostheta+k)
Q.normalize()
print ("kcostheta: %f, k: %f, Q: %s"%(kcostheta, k, str(Q)))
return Q
wealthychef posted Tue, 08 July 2014 at 8:56 PM
Found a solution thanks to  http://mcngraphics.com/thelab/blender/connect/
ep1 = numpy.array(ep1)
ep2 = numpy.array(ep2)
center = ep1 + 0.5 * (ep2 - ep1)
Position of ep2 if an imaginary sphere encompassing
both objects was transformed to 0, 0, 0
ep2new = ep2 - center
Spherical coordinates (radius r, inclination theta, azimuth phi) from
the Cartesian coordinates (x, y, z) of o1 on our imaginary sphere
r = numpy.linalg.norm(ep2new) # radius of sphere
theta = math.acos(ep2new[2]/r)
phi = math.atan2( ep2new[1], ep2new[0])
return (0,theta, phi)
