Aristoc1 opened this issue on Jul 24, 2014 · 8 posts
Aristoc1 posted Thu, 24 July 2014 at 6:08 AM
Razor42 posted Thu, 24 July 2014 at 6:13 AM
Is it possibly the texture map to resemble wrinkles in the cloth?
Aristoc1 posted Thu, 24 July 2014 at 6:30 AM
yes i think the white lines are suppose to be the texture but it comes out very bad.
but the shoes? purple ?
Razor42 posted Thu, 24 July 2014 at 6:43 AM
The shoes look like a specularity color issue, try changing it to black and see if that helps.
with the diffuse for the clothing change it to black and it should overfill the lighter area's.
Aristoc1 posted Thu, 24 July 2014 at 2:05 PM
thanks
RHaseltine posted Thu, 24 July 2014 at 2:17 PM
It looks to be a fairly simple layout -you could just use the surfaces pane to load a plain, tiling fabric square (there are a lot around) and then use the tiling settings to adjust how many times it repeats. You could also look at the Fabricator sets at DAZ, or check other stores or freebie sites for fabric shader presets.
Aristoc1 posted Thu, 24 July 2014 at 2:21 PM
couldnt i just do some editing of that jpg in photoshop and then re-save it?
RHaseltine posted Thu, 24 July 2014 at 2:25 PM
You could, yes - just clone out the light areas from the dark.
I should have said, you need to edit your post to remove the texture image - posting textures isn't allowed.
