EClark1894 opened this issue on Jul 27, 2014 · 27 posts
EClark1894 posted Sun, 27 July 2014 at 5:40 AM
Get a partial shrinkwrap in Blender?
I don't need to do the whole thing. Then I'd just be starting over. But there are times when I need to say just fit the top part of a dress to a figure. Or something like that. What does "Snap to" do and how do I work that if it's what I need?
Cybermonk posted Sun, 27 July 2014 at 7:16 AM
Yup create a vertex group of the area you want use. You can specifie that vertex group in the shrinkwrap modifier.
____________________________________________________
"The true sign of intelligence is not knowledge but imagination".
Albert Einstein
Cybermonk posted Sun, 27 July 2014 at 7:21 AM
Yeah you can use the snap to tweak indiviual verticises. Just set the snap to faces and closest.
Albert Einstein
EClark1894 posted Sun, 27 July 2014 at 7:26 AM
RobynsVeil posted Sun, 27 July 2014 at 7:41 AM
Quote - Yeah you can use the snap to tweak indiviual verticises. Just set the snap to faces and closest.
In this video, the chappie discusses what you need to know at about 2:40 mins into it.
tchadensis posted Sun, 27 July 2014 at 8:00 AM
While learning Blender I discovered that there are a billion....no...really!, I counted them, video tutorials for Blender on youtube. Now that the interface isn't ridiculous and just plain stupid anymore, it's user base has exploded and it seems that everyone is making tutorials. I have yet to have a question (and I've had lots of them) that I couldn't answer this way. A side benefit is that one usually finds answers to questions one didn't even know one had while researching the original question. I keep the videos for reference and have them sorta arranged on a portable drive by category.
Cybermonk posted Sun, 27 July 2014 at 10:41 AM
Albert Einstein
Cybermonk posted Sun, 27 July 2014 at 10:42 AM
Albert Einstein
Cybermonk posted Sun, 27 July 2014 at 10:47 AM
Albert Einstein
Cybermonk posted Sun, 27 July 2014 at 12:22 PM
Albert Einstein
cfpage posted Sun, 27 July 2014 at 1:16 PM
while on the subject (vertes groups)Iam trying to creat a face morph for poser
I have no problems to so exept when doing a smile for instance if I use the sculpt or proportional edit, it effects the teeth how can I make them Isolated from those tools.
thanks.
Cybermonk posted Sun, 27 July 2014 at 1:54 PM
Tab into edit mode select the teeth faces and hit H key this will hide them. Alt+H key to get them back. This will protect them from your sculpting
Albert Einstein
cfpage posted Sun, 27 July 2014 at 2:00 PM
Quote - Tab into edit mode select the teeth faces and hit H key this will hide them. Alt+H key to get them back. This will protect them from your sculpting
that was to easy thank you
Cybermonk posted Sun, 27 July 2014 at 2:18 PM
No problem
Albert Einstein
EClark1894 posted Sun, 27 July 2014 at 3:07 PM
Cybermonk posted Sun, 27 July 2014 at 3:47 PM
Always glad to help my fellow Blender peeps. Besides I needed to take a break from on Blender problems.
Albert Einstein
EClark1894 posted Fri, 15 August 2014 at 11:51 AM
I'm looking to create piping on some clothing I'm making. Here's the problem. I'm making the clothing to be used in Poser's Cloth room. That said, what's the easiest way to make piping in Blender?
Cybermonk posted Fri, 15 August 2014 at 12:40 PM
Piping is like a rounded or folded trim right? You can model it in Blender the problem is Poser. I only have poser 7 myself so I'm not sure about the newer versions but if I remember corectly dynamic cloth needs to be single layer mesh. This piping will not react well with the cloth simulator. Unless you do it with like a bump map.
Albert Einstein
EClark1894 posted Sat, 16 August 2014 at 5:30 AM
Cybermonk posted Sat, 16 August 2014 at 10:21 AM
Sorry to be the bear·er of bad news
It would work with conforminging in Poser. If you were doing it in Blender you could add thickness with the solidify modifier and a vertex group. That would not interfear with the cloth sim. Unfortunaly I think bump map is it for Poser Dynamic Cloth.
Albert Einstein
heddheld posted Sat, 16 August 2014 at 1:37 PM
could try setting the pipping as soft decorated (set it as vertex group in blender)
not sure if it will work ;-)
EClark1894 posted Sat, 16 August 2014 at 3:27 PM
It's just that my texturing sucks. I have about two outfits for Roxie and at least one for Rex that I can't really do anything with because of texturing. And i'm not good enough to model the finer details in Blender yet.
heddheld posted Sat, 16 August 2014 at 4:40 PM
lol
all I can say is we all suck at sumat ;-)
someone told me Van Gogh was deaf in one ear and Da Vinci couldnt stateboard rofl
but one day EClark may be as famous as [insert name here]
just practise/learn ~ do it again but quicker/better
BUT most of all have fun
Cybermonk posted Sat, 16 August 2014 at 8:38 PM
Albert Einstein
Cybermonk posted Sat, 16 August 2014 at 8:42 PM
Albert Einstein
keppel posted Sun, 17 August 2014 at 6:53 AM
Here is how I do this type of piping (Lofting) in Blender.
Select your mesh and in edit mode (edges) select an edgeloop where you want the piping to go.
Press Shift+D followed by enter to duplicate the edgeloop then immediately press "P" and choose selection. This separates the edgeloop from the original mesh without moving its position.
Select your original mesh and press "H" to hide it, you should now be left with the duplicated edgeloop.
In Object mode select your duplicated edgeloop. Press Alt+C and choose Curve from Mesh/Text. This converts your edgeloop mesh to a curve.
In general 3D terms you now have a "path" that you can loft a "profile curve" along.
Now add a bezier circle to your scene.
Select your path curve and in the Properties panel select the Curve tab.
Click on the Bevel Object field (in Geometry) and select the Bezier Circle that is listed.
You will now see the profile curve lofted along the path curve. You will probably find that the lofted shape is way to big. To fix this select your profile curve (Bezier Circle) and scale it down. You may have realised at this point that what ever shape your profile curve is that is what gets lofted along your path. If you select your profile curve and change to edit mode and move the points around you will see the changes in the lofted mesh.
If you unhide your original mesh you will now see that the lofted mesh follows the original edgeloop.
A couple of tips at this stage.
If you still needed to subdivided your original mesh you will want to avoid creating a heavily dense mesh in your lofted mesh.
To adress this select your profile curve.
In the curve properties panel look for the "Preview U" box (in Resolution).
Reduce the default number to around 2-4. If you zoom in on your lofted mesh, then change the "Preview U" number you will see the effect this has on the loft. By reducing the resolution of the loft it will reduce the density of the mesh when it gets subdivided later.
Once your happy with the result select the lofted mesh and press Alt+C and change the selection to "Mesh from Curve". Now you can delete the profiel curve as it is no longer needed unless you have other lofts to do that you want the same profile.
At this stage the original mesh and your lofted mesh will have the same number of rings. So if you need to make the two meshes one continuous mesh you can delete any unwanted faces on the lofted mesh and then "Bridge Edgeloops" to join them.
Now you can subdivide and smooth as required.
My Renderosity Store
Virtual Furnishing
My Portfolio
Cybermonk posted Sun, 17 August 2014 at 8:38 AM
@Keppel nice tutorial Keppel. That is definately the way to do this.
Is there a way though to keep the piping in good shape in Poser's Cloth Simulator? I'm not that great in Poser so I'm not sure.
Albert Einstein
