RenderMarty opened this issue on Aug 19, 2014 · 5 posts
RenderMarty posted Tue, 19 August 2014 at 4:27 PM
It's driving me crazy. I cannot make Victoria's several morph packages and her eye movement i.e. expressions work together.
Here's the thing:
When I create a new runtime and only pupulate it with victoria 4.2 everything is fine. I can load her and the eyes work so do all kinds of expressions.
But as soon as I add Morphs++, have them initialized and inject them Victoria won't close her eyes. Expression work fine execpt that here eyes stay open all the time. This happens even if I don't do anything but loading V4.2. Boom, no eye movement.
I've tried everything:
One tip was to make sure to have only one Victoria 4.2 in the runtime. Disabled and even zipped the other runtimes, no effect.
Another tip was to correct the delta settings for the eye lids. I did that but that only makes the open/close dial from the base morphs work a little. The eyes won't close completely and expressions still don't work.
Any help?
By the way: I had a hard time even to initialize the Morphs. It seems that - with Mac - I need to create all relevant folders by hand as the command-script won't run if the folders have been created by Daz Installer.
(My System: Mac with Mavericks and PoserPro 2014)
hborre posted Tue, 19 August 2014 at 8:56 PM
I don't know how old your V4.2 installer is, but if it isn't current, redownload the files from DAZ. There have been some updates with those files, the most recent may have been earlier this year.
fictionalbookshelf posted Tue, 19 August 2014 at 9:20 PM
I agree with Hborre, if you are using old installers than redownload the installers and install from them. I did have an update or two if I remember right on V4 and M4 this year.
WandW posted Wed, 20 August 2014 at 7:07 AM
Of course, there are no more installers; they are now zip files.
The root of the zip contains a Content folder. Copy the contents of this folder to your runtime location, merging directories. You will then need to run the initialization scripts in Runtime/Libraries/!DAZ after installing V4 and morph packages such as Morphs++, A4, S4 G4 or Elite...
