Subject: conforming item goof up
thewebflea opened this issue on Sep 16, 2014 · 9 posts
thewebflea posted Tue, 16 September 2014 at 8:01 AM
I recently created a conforming skirt
i would like to know how to fix the problem I'm having
when i move the figure's leg I get this
What am I not doing ?????
Figure in T Pose
Leg in T pose
Figure Leg Bent
Leg moved
PhilC posted Tue, 16 September 2014 at 8:09 AM
Strongly suggest that you consider making the skirt dynamic cloth for use the cloth room. You can create a conforming skirt, there are many little tricks that you can use to help it move more naturally but the cloth room will give you much better results much quicker.
thewebflea posted Tue, 16 September 2014 at 8:49 AM
I usually do dynamic clothing most of the time
thought I'd giv conforming a go ....
PhilC posted Tue, 16 September 2014 at 10:40 AM
OK no problem.
For conforming, suggest that you adjust the spherical blend zones to give a smoother transition in the central area.
vilters posted Tue, 16 September 2014 at 10:44 AM
Or?
If you have PP2012 or PP2014, you can Weightmap the skirt (in twist, side-side- and bend). => You have to all 3.
That would solve al your problems.
Oh, and for an issue like this? Show the wireframe, but we see what's happening.
thewebflea posted Tue, 16 September 2014 at 10:45 AM
I think i tried that and nothing was happening
I mustve did it wrong
I'll try again
thewebflea posted Tue, 16 September 2014 at 11:19 AM
I should've said I'm using Poser9
rokket posted Sat, 20 September 2014 at 1:04 AM
You can't create weight maps in Poser 9, but if your figure is weight mapped, it will transfer over if you use their rig as a donor.
The zones will still have to be adjusted. What is happening here is that the skirt now has the hip and thigh bones, so it is behaving like it does.
PhilC's suggestion should fix it.
Anthanasius posted Sat, 20 September 2014 at 2:57 AM
Dynamic ;)
Génération mobiles Le Forum / Le Site
