Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 24 11:54 pm)
What program are you using to generate displacement maps?
And what settings are you using in that program?
Different programs generate and handle displacement differently, so you need to experiment with the settings in the program you're using to make the maps, and then experiment with the settings in Poser for those maps.
Quote - put the alpha in simple transparency.
How do you keep it from getting so warshed out & faded ?
From the image looks like the colour part is being plugged into the diffuse node. If this is the case plug the colour into the ambient node instead. Also if not already done disable shadow on the flame prop.
Also check gamma - you probably forgot to set gamma = 1 on the transparency map.
flame is still warshed out & faded
gamma set to 1
no diffuse ,color map in ambient color
In hierarchy it's just one mesh.
How do you just turn the showdows off for one group ?
It's a real pain to laern new app's till ya get a clue.
Thanks a lot for your all's help ;)
The
Artist that will fight for decades to conquer their media.
How do reset materail room UI to stock UI ?put the alpha in simple transparency.
It's a bump map in the render.
How do you put displacement maps on that look good ?
Thanks for the help :)
