LarryWheeler opened this issue on Oct 07, 2014 · 6 posts
LarryWheeler posted Tue, 07 October 2014 at 6:00 PM
If someone could help me please...My Poser 10 crashes alot before rendering. Here is my system pref
2.5 GHz Intel Core i5
20 GB 1333 MHz DDR3
AMD Radeon HD 6750M 512 MB
Mac OS X Lion 10.7
I just bought 16 gb of memory to try and help out poser 10. When I load large props like streets and small cities. It is too much for my system. I get the error messages that say low memory or error while rendering. both result in poser 10 crashing.
I've tried to run with only two main lighting and I've been working with auto render settings both seem to help. but with larger props like big houses and small cities it still end up crashing.
Anyone have any advice on how to limit the crashes? Thanks
willyb53 posted Tue, 07 October 2014 at 6:27 PM
Poser 10 is a 32 bit application and can not address more than 4 Gig(not sure how MAC different from windows on overhead)
Your best bet it to try render in seperate process
Bill
People that know everything by definition can not learn anything
LarryWheeler posted Tue, 07 October 2014 at 6:45 PM
what poser program would be the best? And how do you render in a seperate process?
willyb53 posted Tue, 07 October 2014 at 6:53 PM
PP2014 is 64 bit and will use all available memory
To use render in seperate process
Select edit>general preferences>render and click on seperate process
Bill
LarryWheeler posted Tue, 07 October 2014 at 7:07 PM
Cool thanks man...It's about time for an upgrade anyway.
Gator762 posted Mon, 13 October 2014 at 8:58 AM
Are you using the latest SR4? My Pro 2014 build is 10.0.4.27796 and it seems to be crashing a lot on me now, AMD R9 280 with latest drivers. I have SLI, but disable in Poser because SLI runs slower. :(
