Forum: MarketPlace Customers
Subject: Render Rewards for October
BorgBoy7 opened this issue on Oct 20, 2014 · 3 posts
BorgBoy7 posted Mon, 20 October 2014 at 10:17 AM
I just noticed that I hit the second level for the Render Rewards for October.
My problem is that it is only showing that I reached the 1st tier and will only recieve 3% back after spending $70.  I have curently spent $108.75 and it should reflect that I will be getting 7% back at the end of the month, not 3%.  If it's a glitch and just isn't showing the right percentage recieved at the end of the month then no big deal but I thought I should check to be sure.
StaceyG posted Mon, 20 October 2014 at 10:30 AM
Since this tiered render rewards promotion is a special we do every so often, the system isn't set up to show those tiers, it can only show one which is the minimum one (the $70.00) but I promise it will reflect the appropriate level you've reached when the render rewards % is put on your account Nov 1st!!
Thank you
Stacey
BorgBoy7 posted Tue, 21 October 2014 at 12:03 PM
Quote - Since this tiered render rewards promotion is a special we do every so often, the system isn't set up to show those tiers, it can only show one which is the minimum one (the $70.00) but I promise it will reflect the appropriate level you've reached when the render rewards % is put on your account Nov 1st!!
Thank you
Stacey
Oh good, thanks for replying!
