BowlingKaz opened this issue on Nov 05, 2014 · 6 posts
BowlingKaz posted Wed, 05 November 2014 at 4:11 PM
Anyone having trouble with the render preview window? It is fragmented even though the actual render turns out fine.
hornet3d posted Thu, 06 November 2014 at 6:48 AM
Is the fragmentation on every scene? I have used 2014 and now game dev and I have not seen the problem but I have noticed it does not handle some effects well. Also it renders at a longer focal length than the actual render so is there anything close to the camera that might be to blame.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
piersyf posted Thu, 06 November 2014 at 4:15 PM
If you want to check the full scene, using the same focal length and framing at the full size of the final render, go to scripts>partners>dimension3D>render firefly and on the left side of the box under 'quality' there is a check box for progressive mode. Tick that. Hit render. Cancel render when you have seen enough. You get a good sense of lighting distribution and texturing in a few seconds. If happy, just untick that box and render as normal.
false1 posted Mon, 10 November 2014 at 11:47 AM
Pro 2014 has that option built in. I just found out about it recently and it's changed my life :-)
________________________________
false1 posted Mon, 10 November 2014 at 11:52 AM
narsil posted Fri, 14 November 2014 at 1:51 PM
What graphics card have you got?
I have had the same problem with with the PREVIEW window
there is a work around if you have an AMD card -
