Subject: Changin Document Window Size
ralphkramden39 opened this issue on Nov 24, 2014 · 7 posts
ralphkramden39 posted Mon, 24 November 2014 at 1:29 PM
 Windows 7, Poser Pro 2012
Hi,
I've always rendered according to the size of my display window, which is 1135x816 - I'm assuming that is the dimensions out of the box, because I don't recall changing it - and then when I render, I make the render larger, but use the same dimensions ratio, so that what I see on the poser window is exactly what  I get in my finished render (I hope that makes sense). Anyway, I'd like to try my hand at an illustrated novel on Amazon, which call for a 9:11 ratio. How do I change that in Poser? When I go to Window - Document Window Size, it says I have to "Float Palette". I do, then I type in "1002 x 1502" and it automatically defaults to   1002 x 1050. I want a Poser window that is 1002x1502. Is that impossible.
I'm sending this from an airport, about to step on a plane. Will land in a couple of hours and hopefully someone can help me out. Thanks!
