Forum: Carrara
Subject: Upscaling a 3D Animation to 1080. How to speed up your rendering.
SciFiFunk opened this issue on Dec 11, 2014 · 6 posts
SciFiFunk posted Thu, 11 December 2014 at 6:46 AM
I wish I'd thought of this earlier. The idea came to me as I'm under pressure to produce a lot quicker than I have been.
https://www.youtube.com/watch?v=kGW8F3s0Hmg&feature=youtu.be
How to speed up 3D Animation rendering using upscaling for certain shots. more at https://www.facebook.com/scififunk?ref=hl
A variety of tactics to speed up your rendering by using smaller images and upscaling.
When to use this, how it relates to DOF, and grain removal.
MarkBremmer posted Thu, 11 December 2014 at 8:37 AM
A well used trick to create a more film-like visual – and a huge time saver.
SciFiFunk posted Thu, 11 December 2014 at 8:38 AM
Ah. I was behind the curve then. It only took me 5 years to shed my idealism. lol.
bhoins posted Tue, 30 December 2014 at 11:44 AM
Depends on what you composite in, another trick is to use Multi-pass rendering (Pro only feature) render out the Velocity pass, then you can render 1/3rd to 1/2 as many frames. The velocity pass information helps fill in the blanks. :)
SciFiFunk posted Tue, 30 December 2014 at 12:58 PM
That's an interesting idea. Is is borrowing from an animation favourite of tweening between frames? Octane now has render passes I'll see if it has a velocity pass and give it a go. Cheers.
cjd posted Wed, 31 December 2014 at 2:11 AM
Project Dogwaffle has a motion prediction (interpolation) algorithm, which can produce in between frames from existing rendered frames. While it is a 32 bit application, this function is pretty fast.
http://www.thebest3d.com/howler/7/motion-prediction-module.html
