madmitch opened this issue on Dec 15, 2014 · 11 posts
madmitch posted Mon, 15 December 2014 at 10:38 AM
Is there any way of temporarily stopping background objects being highlighted in orange when the cursor moves over them? I find it very distracting when posing a foreground figure. I am using DAZ 4.7
manleystanley posted Mon, 15 December 2014 at 2:12 PM
Ahh, no. That is done on purpose so you know which object the pointer is on to select. If you turned it off you wouldn't be able to tell if the pointer is on the object you want to select. You can always select the body part to pose in the figure tree in the scene menu and not use the pointer.
RHaseltine posted Mon, 15 December 2014 at 4:55 PM
Go to the Tool Settings pane (Window>Panes(Tabs)>Tool Settings) and in the Node Highlighting group set Draw Style to Bounding Box only.
Angel_Natavi posted Mon, 15 December 2014 at 8:44 PM
Ahh, thank you. I find it useful only for a small amount of time. When I'm rigging, and/or going through a complicated scene with alot of stuff, it gets annoying more so than anything else.
In order to go forward, one must often times look to the past.
madmitch posted Tue, 16 December 2014 at 6:11 AM
Many thanks Richard,
ldgilman posted Thu, 29 January 2015 at 12:17 PM
My thanks also, I just made the changes and it is (for me) easier to get around and see things without constantly moving the cursor off screen.
bhoins posted Fri, 30 January 2015 at 1:24 PM
One other thing, you can set the opacity to a level that is less distracting but still lets you see the nodes highlighted.
Rorsdors posted Tue, 03 February 2015 at 8:08 AM
Thanks, I couldn't see my way around with the highlighting, glad to be rid of it, hurrah!!
Navi posted Wed, 18 February 2015 at 5:20 PM
Sometimes, I change properties on background props too, this can be useful sometimes ("display" menu on props/figures, you can set display off for any items getting in the way with highlight).
Navi posted Thu, 19 February 2015 at 4:36 PM
...Oops, I mean "selectable" option, in the display menu :)
