Subject: Gradient bump lower than 1.0 + hardware shading = a bad time.
Vaskania opened this issue on Dec 15, 2014 · 4 posts
Vaskania posted Mon, 15 December 2014 at 8:20 PM
Can anyone help me with the proper usage of a tangent space normal and the gradient bump connection?
I'm testing a product (unreleased, hence no screenshots) which uses normal maps plugged into gradient_bump. They're set to tangent space and 0.5. The figure looks horrible and splotchy if I leave hardware shading on. The texture only looks normal if I either turn hardware shading off, or change gradient_bump to 1.0.
I always leave hardware shading on, but I've never ran into this issue. Is the proper solution to turn off hardware shading, or to change the texture's gradient_bump to 1.0? Or is this a bug altogether?
I'm using PP2014 Game Dev SR5 and set to inches.
/edit
Gamma on the normal is 1.0.
file_9dcb88e0137649590b755372b040afad.pn
-----sig-----
Daz, Blender, Affinity, Substance, Unity, Python, C#
Teyon posted Mon, 15 December 2014 at 10:47 PM
Set it to 1.  Leave it there.  I honestly don't think the setting was intended to be dialed lower than that, which is why it looks so funky when you do. I always use it set to 1 and only have problems when the team forgets to switch the feature on during beta releases. :-)
Vaskania posted Mon, 15 December 2014 at 10:56 PM
Thank you! :)
-----sig-----
Teyon posted Mon, 15 December 2014 at 11:12 PM
Happy to help.
