Subject: Putting a P5 DON head on a P7 Simon figure?
hamiltonpl opened this issue on Dec 26, 2014 · 6 posts
hamiltonpl posted Fri, 26 December 2014 at 6:51 PM
Likely this has been asked and answered and I apologize in advance.   Is there a way to easily put a P5 Don head/morph onto the P7 Simon Figure?  I ask because I have a good faceroom result that I just cannot get with the Simon head - however the body has morphs I need that the P5 does not.
I know that I can attach - I presume - the P5 to the P7 figure and make one head invisible and the other not.  But, is there any other way to make this happen?
Thanks.
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
WandW posted Sat, 27 December 2014 at 8:59 AM
You could try the Morph Brush.  This works on body shapes, but I haven't yet tried it myself on a face...
EDIT: Nudity in link
http://forum.runtimedna.com/showthread.php?79163-The-Morph-Brush-Transfering-FBMs-to-other-characters.
hamiltonpl posted Wed, 07 January 2015 at 10:42 AM
Darn it.  I have Poser Pro 2012.  That Tighten option is available until Poser 10 - the next release after this one.
Any other ideas on getting a P5 morph onto a P7 Simon?
Teyon posted Wed, 07 January 2015 at 1:31 PM
You could do two renders with the same lighting and pose. One of Don and one of Simon. Then cut Don's head off in a paint program and paste it over Simon's head.
Other options that I could think of would require projection in ZBrush that could call for massive cleanup, making the whole thing really not worth the effort.
vilters posted Wed, 07 January 2015 at 5:14 PM
 Long time ago, must have been around 2005-2006 right after the P5, release,  someone here put the P4 head on the P5 male.
In a 3D app, he cut out the P4 head including half the neck to reuse, and cut the head including half the neck, off the P5 male.
Then he build a obj file using the P4 male head, and the P5 male body, and reconstructed the polygons to build a new neck and to group them back together.
Then he edited a cr2, to use the P4 head and the P5 body.
All morphs worked on head and body.
But I remember he lost the neck morphs and had to rebuild those as well.
If, and I say if, there are somewhere archives about the 2002-2006 period, it must be there somewhere
I used to have a printout, but. . . . . . Tja, we are 2015 and so many Poser versions and figures later.
A cr2 guru, can certainly pull off something like this.
hamiltonpl posted Wed, 07 January 2015 at 5:21 PM
Interesting.  What I did do is parent the P5 neck to the P7 neck.  So now I have a P7 body with the P5 head. Of course I am making the P5 body invisible. And because he's wearing a turtleneck - it covers up the seams but I matched them pretty well and you can't tell.
The reason I did this was I wanted to have a more pear shaped body with the FBMs available with Simon.  They aren't there for P5 Don.
This is for an animation so as I import BVH files in they will be applied to the Simon body.  A lot or trouble in a way but I wish there were a more seamless way of doing this with the CR2 file. That would be nice.
