drifterlee opened this issue on Jan 24, 2015 · 6 posts
drifterlee posted Sat, 24 January 2015 at 7:16 AM
HI: I just purchased several V6 pose sets from the RMP and this is what I get. A cracked head and gray stuff showing through V6. Does anyone know what is causing this? Thanks. See attach
ment. Thanks
hborre posted Sat, 24 January 2015 at 7:22 AM Online Now!
Looks like a UV texture problem. Did you try switching skin textures on V6?
RHaseltine posted Sat, 24 January 2015 at 8:22 AM
Yes, it looks as if the pose also includes the UV set property, which generally it shouldn't - or even full materials, if the skin has changed.
aldebaran40 posted Sat, 24 January 2015 at 10:45 AM
if you will apply the skin mat after pose , ¿ the problem continues?
drifterlee posted Sun, 25 January 2015 at 3:49 PM
Yes, the problem continues and it does it with all the textures when I used those poses.
hborre posted Sun, 25 January 2015 at 5:28 PM Online Now!
http://www.sharecg.com/v/73633/related/21/DAZ-Studio/UVSetterGen2-Revised-10-2014
Get this script from sharecg.com and use it to reset the character UV. There is no reason for ordinary pose files to change the UV unless these are MATfiles to change skin textures. The Vendor should be notified about this problem and corrected ASAP. BTW, which products are causing you problems?
