Subject: I messed up my screen somwhow
darren3D opened this issue on Feb 06, 2015 · 5 posts
darren3D posted Fri, 06 February 2015 at 4:55 PM
I'm learning to control the Dolly camera using the ctrl/shift/N menu.  I pulled to stretch it taller so I could see all the parameters and I did something wrong. Now this menu is almost entirely covering the screen where I should see the background and figure. Here's a screen shot.  I hit ctrl/shift/N again and it goes away but when I bring it back up it covers too much of the screen again.  How do I get it back to a small menu again?
file_a2557a7b2e94197ff767970b67041697.jp
geep posted Fri, 06 February 2015 at 5:03 PM
Try this.
cheers,
dr geep
file_02522a2b2726fb0a03bb19f2d8d9524d.jp
cheers,
dr geep ... :o]
edited 10/5/2019
hborre posted Fri, 06 February 2015 at 5:52 PM
Or else, go back into General Preferences an set Poser to relaunch with factory defaults.
Daffy34 posted Fri, 06 February 2015 at 6:52 PM
Yes, looks like you basically left the interface at factory settings, so I'd do what hborre says in this instance ;).
willyb53 posted Fri, 06 February 2015 at 7:49 PM
And after you get it the way you want, set a UI render dot so you can reset it without going through a lot of problems :D
Bill
People that know everything by definition can not learn anything
