Boni opened this issue on Feb 12, 2015 · 72 posts
Boni posted Thu, 12 February 2015 at 6:24 PM
I'd like a more vibrant and procedural mats for lipstick textures for V4, (PP2014) Suggestions.
References:
Boni
ghostship2 posted Thu, 12 February 2015 at 9:56 PM Online Now!
you could use a mask for the defuse and one for the reflect on the face mat. That would separate the shiny parts from the skin tones. I do that sort of thing all the time for decals and such.
ghostship2 posted Thu, 12 February 2015 at 10:05 PM Online Now!
like this
MistyLaraCarrara posted Fri, 13 February 2015 at 7:49 AM
that looks nice.
blurred reflection-ish
Boni posted Fri, 13 February 2015 at 8:19 AM
Hmmm. That looks great ... trying to figure the soft edge for the lip ... Let me see what I can do. Thanks, this is wonderful.
Boni
pumeco posted Fri, 13 February 2015 at 8:42 AM
@Boni
You just need to blur the edge of the mask.
Boni posted Fri, 13 February 2015 at 8:49 AM
Thanks!!
Boni
Boni posted Fri, 13 February 2015 at 10:08 AM
Ok, it's only fair that you see how this turned out. Here you go. :)
Thank you my friends! this is great!
Boni
Boni
ghostship2 posted Fri, 13 February 2015 at 11:55 AM Online Now!
Here is a little more complex way of doing it. I don't do the math stuff so I leave that to EZSkin2. The shader you see here is just a texture and bump ran through EZSkin. I have marked in red the new nodes for the reflective stuff and the yellow dashed line is where EZSkin normally hooks everything up. Also, I don't use Poser lights all that much and this image uses none. All lighting is coming from BB's EnviroSphere. Somebody else might be able to figure out how to incorporate glossy speculars when using the Poser lights. Also, also, shifting the blender blend control nearer to 0 makes it look more like lip gloss than reflective paint.
ghostship2 posted Fri, 13 February 2015 at 12:09 PM Online Now!
Also, If you need other colors you can slip a simple color node between the blender and reflect nodes and choose the color you want.
ghostship2 posted Fri, 13 February 2015 at 1:23 PM Online Now!
I found some problems with that last shader I made. The darker the color the less reflective it became. Here is a better version of that. Play with the blending setting to make more of a lip gloss look, change the color in the simple color node and also change the reflect softness if you want it more mirror like.
Boni posted Sat, 14 February 2015 at 3:35 PM
Ghostship2: your mask is perfect, where/how do I get/make such a perfect mask? I have been struggling with it for over a week.
Boni
ghostship2 posted Sat, 14 February 2015 at 3:52 PM Online Now!
it's kinda sloppy but here it is. I hope this helps.
Boni posted Sat, 14 February 2015 at 4:41 PM
Thank you so much!
Boni
Boni posted Sun, 15 February 2015 at 11:45 PM
I feel foolish for asking this, but I can't seem to use or adjust a lip mask so it's up to the the edge of the lip zone but still soft edged enough to blend seamlessly with the adjoining face map. Surely this is possible. Help please.
Boni
pumeco posted Mon, 16 February 2015 at 7:25 AM
You have my sympathy, just another reason I can't stand multi-map designs - they're a pain in the arse to work with.
I could be wrong but I think you need to use something that allows you to paint across seams directly on the model. Alternatively, and I don't know if it would work for V4, but Vilters discovered quite a biggie in getting rid of zones and merging them into one. Maybe visit the thread and ask Tony if it will be possible for V4 because that trick he found is pretty damn neat for getting rid of multiple maps - it'll make your life a lot easier if it works.
Click Here for the thread, but I recommend you ask before you try it, just to be sure.
Boni posted Mon, 16 February 2015 at 8:02 AM
As I commented in the other thread, overlays and displacement/bumps created in nodes would be disproportionate on a single map ... The head is not in proportion with the body etc. ... but a very interesting approach. Also since my ultimate goal is to make characters for the marketplace this would be counter-productive. Let me emphasize though that for personal projects this is a wonderful idea! I don't want to devalue this idea. The other challenge I have concerning multi-map designs is since they are dis-proportionate to each other I've been seeking a ratio setting of the proportions to establish changes in the size of referenced overlay nodes so that it all comes together in the final render ... all in a form that in the end will work with a marketable character. But that is another issue. Right now the mask for the lips is my concern, and I would need that no matter that mapping design it was since I need to alter the texture of the lip separate from the body. Lots of things to think about.
Boni
Boni
pumeco posted Mon, 16 February 2015 at 11:13 AM
Sorry Boni, never thought about that aspect of it.
Boni posted Mon, 16 February 2015 at 6:34 PM
NP, I've been overthinking this for a couple years now as I prepare to become a vendor. I just wanted to try some new approaches to give users a fresh character base.
Boni
ghostship2 posted Mon, 16 February 2015 at 7:46 PM Online Now!
I'm confused. In the renders that I did I used the same mask and shaders on both the lips AND the face. the mask runs past the lip boundary. I had no problems at all with how the mask worked. Also, these are for V4. If you are using another figure then you would need a different mask.
ghostship2 posted Mon, 16 February 2015 at 7:56 PM Online Now!
I don't think it is. I've tried to do the same thing and always get that razor-sharp edge....your lip textures have to either be larger than the lips or smaller than the lips and have surrounding mouth flesh as part of the lip texture. You will also note that when you buy a character pack with multiple lip colors the vendors leave part of the mouth skin/texture to blend with the lips. It's just not practical to try to get right to the edge. Same reason I use iris textures that are larger than the iris so I don't get that razor-sharp-robot-eys look on my figure.
Boni posted Tue, 17 February 2015 at 9:25 AM
Well, after about 10 more hours working on it ... I think I've got it as close as I can. Slight edging, but at a normal resolution and distance I think it will be ok.
The primary reason I'm doing this is so that I can mask more effects for the lips. blending with the surrounding mouth works very well for standard lipsticks, but once you have effects like gold, silver ... glitter, what have you ... the rules change slightly therefore the mask. But this can be applied to standard lips too so the process done once can be applied again and again and individual lip blends may not be necessary.
What do you all think?
Boni
Boni
ghostship2 posted Tue, 17 February 2015 at 11:33 AM Online Now!
Hey Boni
the border around the lip looks unnatural. this is mine with the same shader that I posted up earlier. Again...no lights, BB's Envirosphere and EZSkin2. Are you using poser lights in your render?
Boni posted Tue, 17 February 2015 at 11:34 AM
Ok, here are my lip samples for your consideration. Marketable?
Boni
ghostship2 posted Tue, 17 February 2015 at 11:37 AM Online Now!
Maybe you could post up your shader and lighting setup. Or just PM me and I can take a look at it.
Boni posted Tue, 17 February 2015 at 11:42 AM
Will, do, but I will be busy today and may have to wait until tomorrow. Thank you. :)
Boni
Miss Nancy posted Tue, 17 February 2015 at 1:43 PM
one might use BB's basic metal shader for this. e.g. no diffuse, add refl/blinn nodes via colour math, attach math node to fresnel, which then goes to alt diff chan. uncheck refl_lite_mult, use IDL et al.
ghostship2 posted Tue, 17 February 2015 at 1:55 PM Online Now!
Hey Miss Nancy,
BB certainly knows his stuff but sometimes those complicated Fresnel reflect nodes just get out of hand. There are instances when I can't tell the difference between a simple reflect node plugged into the reflect channel and one of his hundred+ shader trees.
I think my simple masked reflect shader should be all you need. (take a look at the pictures above.)
DeathMetalDesk posted Tue, 17 February 2015 at 3:12 PM
Agree with ghostship2 about the effectiveness of the more simple shader... I spent a couple of agonizong days trying to create a glossy eyelid shader with masks and was dealing with trying to blend three or more different specular effects on basically the same map. ended up using a blinn on the overall face, a two blinn blend on the lips (I find using a mix of 2 blinn settings yields a better looking gloss than just a straight glossy node for lips), and a soft reflect on the lids.
When I first started the shader I was using some things BB was doing with vss and quickly found myself lost within a tangle of math spaghetti, ended up reverse engineering a couple of more simple vendor shaders and using some of BB's base specular settings in the mix. I think that much of the quality is derived from the time spent creating the masks (you might consider a combination of blur and noise at the masks edges to give a different effect), time spent experimenting with the actual settings of the specular nodes themselves, and the effectiveness of your bump maps and their settings (can't overstate this one enough).
Anyway... thanks for the screencaps ghostship2. Filed.
DeathMetalDesk posted Tue, 17 February 2015 at 3:36 PM
Oh yeah, forgot to mention. Not sure if this has been brought up already but, you'll get better results with a lip mask if you derive your selection from the unique diffuse texture boundries of that particular character texture rather than trying to fudge it with a generic mask or one derived from a template/seam guide.
ghostship2 posted Tue, 17 February 2015 at 3:57 PM Online Now!
Thant makes sense. If the lips on your character are differently shaped than the one I made the mask from you are going to have problems.
Miss Nancy posted Tue, 17 February 2015 at 4:13 PM
BB's basic metal shader has only 4 nodes (see below). youse may be thinking of BBglossy, which is more complex.
Boni posted Wed, 18 February 2015 at 6:57 AM
Ok ... here are my settings:
Lip setting for the Lavender lips
Sky setting using RDNA's skydome. (It's simpler than the envirosphere for scenes like this)
My Render settings are:
Now I do have another light in the scene, an infinate light, but it's diffuse and specular are turned to black so that it is used to light the preview window only. Now does it matter than in preview mode the lips show up as black? like the inverted mask?
I think that is all the settings.
I did notice on some of the renders by ghostship2 that the lips are extra bright, saturated ... while mine have more contrast. Could the contrast be the cause of the shadows around the lips?
Look forward to more responses.
Boni
P.S., gholstship2, please feel free to PM me with information you feel sensitive for any reason. :)
Boni
Boni posted Wed, 18 February 2015 at 9:57 AM
ok ... I think I found my boo-boo. I've been doing this in the lip zone all along, NOT in the face zone. How do I do this wiithout messing up the nodes I've already run through EZskin2? Where do I connect the masks AND what do I do with the lip zone?
Boni
ghostship2 posted Wed, 18 February 2015 at 3:01 PM Online Now!
Hey Boni
take a step back to the first page of this thread and I have pointed out were you need to hook everything up....BTW you need to use the same ezskin setup for the lips as the face (there is a check box for this i think) so you don't get a line on the border.
Miss Nancy,
I checked out that shader and it's simple enough for what Boni is doing and it adds speculars. Thank you and here is the settup and results.
ghostship2 posted Wed, 18 February 2015 at 3:03 PM Online Now!
Boni, let me look over you stuff for a bit. And yes, my figures lips look like yours in the preview as well.
ghostship2 posted Wed, 18 February 2015 at 3:10 PM Online Now!
my render settings for hi rez output. This is set up to be efficient on my slow i5 but also give good clean results.
Boni posted Wed, 18 February 2015 at 3:30 PM
Just discovered the discrepancy and am working on that now. And thanks for the heads up on duplicating the settings for both face and lips, the simplicity of that answer makes me feel like a V8 moment (i.e. I want to slap my forehead). :)
Boni
ghostship2 posted Wed, 18 February 2015 at 3:38 PM Online Now!
Boni,
Id say a big problem is your render settings. Your min shading rate is lower than the setting I use for drafts. Pixel samples can be lowered if you are making large renders and that will help speed up your render time. If your scene is lit well you can lower IC and IDLQ like I have in my settings. I never have a problem with IDL splochies an such. Use tone mapping if you want to brighten the scene even more without adjusting lights.
Also you might want to use BB's Sphere all the time instead of the one you are using. It really helps light up the whole scene. let me find a render on my HD
ghostship2 posted Wed, 18 February 2015 at 3:49 PM Online Now!
Ok, Here is an example using BB's Enviroshere for lighting. I do have one poser light set up but it is behind the girl and pointed toward the camera a little. The background picture is a 360 degree photo.
Boni posted Wed, 18 February 2015 at 3:55 PM
ghostship2: I'm a little confused as to how the nodes are connected ... I have a visual impairment and those pale lavender/pink "cables" are confusing me.
Boni
Boni posted Wed, 18 February 2015 at 3:57 PM
Ghostship2: that is beautiful! Now to get it hooked up properly and re-make my metals to hook up properly as well. Thank yo sooooo much for your help.
Boni
ghostship2 posted Wed, 18 February 2015 at 4:28 PM Online Now!
Maybe this will help
Boni posted Wed, 18 February 2015 at 4:30 PM
FANTASTIC! These old eyes thank you! Let me set something up and I'll show you the results!
Boni
Boni posted Wed, 18 February 2015 at 4:36 PM
Unfortunately my new best friend ... it's the other connections I can't see. Not sure what is hooked where.
Boni
ghostship2 posted Wed, 18 February 2015 at 6:37 PM Online Now!
Hey Boni
This one is blown up a bit and I made the links easier to see. The dotted green line is the default link that ezskin will have when you start.
Boni posted Wed, 18 February 2015 at 7:28 PM
I'm doing something dreadfully wrong. Here is a screenshot. I've lost all my great metalics and now I'm getting neon. sigh Back with you tomorrow.
LOOKS like we cross posted ... I'll look at this tomorrow. thank you so very much.
Boni
ghostship2 posted Wed, 18 February 2015 at 7:55 PM Online Now!
check the numbers in your nodes. They are not the same. I just copied the nodes that Miss. Nancy had posted up. You have the nodes hooked up right but the numbers are all wrong. Also, I'm not sure about the "inner color" in your fresnal blend. In Miss Nancy's post the inner color is black and you have some version of orange.
Boni posted Wed, 18 February 2015 at 9:12 PM
When I had it as black the lips turned black and wouldn't change to the desired color ... Since my numbers are all wrong I will re-adjust and try again tomorrow when I am back on my work computer.
Boni
Boni posted Thu, 19 February 2015 at 6:36 AM
MissNancy's metal. BUT in all fairness I did not make the main diffuse deep rust, as that would have made an edge to the lip again. There most be a key in the inverted mask as I had in the beginning, but still trying to get rid of the edge. I would really like the actual textures of the lips (minus edge) to be like I had them before. Any suggestions?
Boni
Boni posted Thu, 19 February 2015 at 8:42 AM
I've been tweaking settings within the new "branch" of nodes and came up with the "new gold", here is a comparison with the old gold that had the "bad" edges. I would have changed the settings as suggested, but I wanted to do a direct comparison and needed consistency for that.
Boni
pumeco posted Thu, 19 February 2015 at 10:50 AM
Well there'll be no stopping Boni now the seams have been sussed!
And nice work on that render of the girl sat at the coffee table, Ghostship :-)
heddheld posted Thu, 19 February 2015 at 11:29 AM
looking good !! not too sure I'd kiss a gurl with metallic lips ;-) and don't see too many probs with edges but I DO like the effects your getting
if its the mismatch between the face/lip tex add some lip liner to the face map
Boni posted Thu, 19 February 2015 at 2:41 PM
Thanks guys! Another nice thing about this is standard lips can be applied this way as well and save future hours of texturing. I'm also thinking of making a mask for the iris to apply the same technique. Great for SIFi and glowing eyes without a sharp edge. Hehe. AND eye shadow. Yes gentlemen (and ladies who are reading ... and may be on this thread, gender is hard to detect sometimes) there is no stopping this old crone now!!! While I'm waiting for my new master set of lips to render ... how would I incorporate a traditional lip image map into the mix ... not making it metalic, but just saving time texturing the original face? In other words where would I plug in the map to use the mask and a selected effect from the new node set?
Boni
Boni posted Thu, 19 February 2015 at 4:43 PM
Here you go ... Lip sample 2 with all the colors I've done:
Boni
Boni posted Thu, 19 February 2015 at 4:45 PM
Thank you all for your help. Just that one last question on using standard lip image maps in the new node. How?
Boni
Boni posted Thu, 19 February 2015 at 7:14 PM
How about a glossy red lipstick?
Boni
ghostship2 posted Wed, 25 February 2015 at 3:25 PM Online Now!
Sorry for not responding. Looks like somehow I became un-subscribed to this thread. Let me look this over.
Boni posted Wed, 25 February 2015 at 3:55 PM
Look forward to your response. :)
Boni
Boni posted Wed, 25 February 2015 at 4:24 PM
By the way I would also like the thank MissNancy for leading me in the right direction right beside ghostship2! Forgot the thank you.
Boni
ghostship2 posted Wed, 25 February 2015 at 5:20 PM Online Now!
try setting your min shading rate to .20 and give us a test render.. Are you using a bump map or procedural bump?
Boni posted Wed, 25 February 2015 at 6:23 PM
It's a blend of bump and displacement. Made the change (.20 in shading rate) it's been 2 hours and it's still rendering. Just the lips? The Jeopardy! theme continues to go through my mind ... do do do do do do do ...
Boni
Boni posted Wed, 25 February 2015 at 6:53 PM
Ok, here we go ...
I admit I really like the result! May I be so bold as to say "Wow" for my own render?
Boni
ghostship2 posted Wed, 25 February 2015 at 8:01 PM Online Now!
It's the other settings you are using that are bogging down your render time. I'm half way through the final render pass on a similar sized render and it has only been 10 min. Take a look at my render settings on previous post.
I'm not a fan of procedural bump maps...esp up close. But that is a personal thing I guess. When I get a new character morph/texture package I always make sure to give the bump map some love in Photoshop to fix stuff. Usually they just make a black & white jpg and forget that the dark eyebrows make a dip in the bump instead of a hill. Other times the vendor will just invert the whole map to make the eyebrows and moles correct but then you end up with the cracks in the lips pop up like veins.
Looks like you got the shade part down! I would say that there still is a disparity between your texture map and the shader mask. If you want, send me the texture map that you want to use and I'll make a mask for you.
Boni posted Thu, 26 February 2015 at 8:02 AM
I looked over my files ... and found I had "crappy" lips on my base face texture ... well, the edges were bad and I can see that in this render upon further examination. So ... let me work on that a bit before I submit a file. By the way I had the same settings you had shown me for the render-settings, except I had 6 raytrace bounces and as usual I had displacement maps checked. After a course several years ago in Lightwave I was so thrilled at having displacement mapping finally in Poser I take advantage of it. That'll slow me down! More later. It will be sporadic today, I am taking care of my partner who is home sick. More later. :) And thank you Ghostship2 for all your help.
Boni
Boni posted Thu, 26 February 2015 at 8:44 AM
Here is a reduced size and reduced raytrace bounce (3) plus the fixed edges on the base face texture. Only took 20 minutes to render. whew.
Boni
Boni posted Sat, 13 May 2023 at 11:33 PM
Ok ... Now to do this in Poser 13! Care to give a it try guys??
Boni
ghostship2 posted Sat, 13 May 2023 at 11:55 PM Online Now!
@Boni Take a look at my thread about subsurface scattering in the P13 forum
https://www.renderosity.com/forums/threads/2978516/cycles-based-sss-skin-shader
Boni posted Sun, 14 May 2023 at 5:00 PM
Lovely! Now to recreate the metallic lips!
Boni
dadt posted Mon, 15 May 2023 at 9:30 AM
I have been trying out the metallic lipstick textures and this is what I ended with. No fancy sets of nodes, just add reflection. The full reflection gives a very harsh result as though the lips were solid metal so I set the reflection at .7 and the normal colour map at .3 giving the effect of a thinner coat of lipstick. No attempt to soften the edges as this is not needed except for extreme close-ups.
hborre posted Mon, 15 May 2023 at 11:36 AM
This thread has moved on to Superfly rendering.I have been trying out the metallic lipstick textures and this is what I ended with. No fancy sets of nodes, just add reflection. The full reflection gives a very harsh result as though the lips were solid metal so I set the reflection at .7 and the normal colour map at .3 giving the effect of a thinner coat of lipstick. No attempt to soften the edges as this is not needed except for extreme close-ups.
dadt posted Mon, 15 May 2023 at 12:12 PM
This is a firefly render, why move it ,the original thread was about Poser pro 14 materials.
