Forum: Carrara
Subject: Bad Birdy is being awfully bad in Carrara
Wonga opened this issue on Feb 24, 2015 · 6 posts
Wonga posted Tue, 24 February 2015 at 7:05 PM
Bought this product yesterday
http://www.renderosity.com/mod/bcs/bad-birdy/108822/
Bad Birdy loads ok in Carrara 8, 8.5 & 8.5B
but you can't pose him manually or with the supplied poses in any of those Carrara versions..
Is there a workaround that can be used to get the bad fella to work in Carrara or should I just pluck him off
file_fc221309746013ac554571fbd180e1c8.jpfile_bd686fd640be98efaae0091fa301e613.jp
Find my Facebook Page Here -- or me on Twitter
Wonga posted Tue, 24 February 2015 at 7:07 PM
Also,
I've tried Fenric's Poser weight map injector and it just crashes at the second part of the procedure :-(
I've also opened him up in DS and saved as DUF and opened in Carrara to no avail..
Xerxes0002 posted Tue, 24 February 2015 at 8:04 PM
Did you try the FixPoseChannels from Fenric? I believe that is what is happening if my memory serves me right from when I had to use it.
it is a .net which makes it a windows utility
http://www.sharecg.com/v/60711/browse/10/Software-and-Tools/Fix-Pose-Channels-for-Carrara
Wonga posted Tue, 24 February 2015 at 9:50 PM
thanks,
yes I have also tried that to no avail.. looks like it will be getting the chop :-(
MarkBremmer posted Tue, 24 February 2015 at 11:10 PM
You shouldn't have to, but it wouldn't take much to re-rig it in Carrara and make it work.
Wonga posted Wed, 25 February 2015 at 12:16 AM
Yep, I did start to try that then thought maybe if  export it from DS as a collada file it may work..
and it kinda does.. still trying other stuff on this bad boy
file_0777d5c17d4066b82ab86dff8a46af6f.jp
