Subject: Lighting Preview icons, Is there a way to make them more visible?
putrdude opened this issue on Feb 27, 2015 · 8 posts
putrdude posted Fri, 27 February 2015 at 4:18 PM
Is there a setting somewhere that will make the preview outlines of lights more visible when visible?
I think I'm going to go blind looking for these things.  The spots are pretty easy to "spot" hehe, but the tiny indirect outline of a circle in a circle almost disappear at certain angles.
Thanks!
Daffy34 posted Fri, 27 February 2015 at 4:25 PM
You can scale them up. Scaling them does not change their light properties, it only changes the light preview.
putrdude posted Fri, 27 February 2015 at 4:51 PM
Thank you. That will help tremendously.
Morkonan posted Sun, 01 March 2015 at 10:05 AM
Thanks!
Go to "Render Settings -> Preview Mode." There is an option to choose the "Silhouette Outline Width"  for silhouette and wire-frame outlines on those sorts of rendered objects. I think that will do the trick for you, since that's all the light/camera bodies are.
putrdude posted Sun, 01 March 2015 at 3:57 PM
O-M-G that worked perfectly. Thank you so much.
Morkonan posted Mon, 02 March 2015 at 9:28 PM
You're welcome!
(I refuse to get glasses, even though I know I need to... So, handy little things like that help me continue to maintain blissful ignorance regarding aging body parts... ;) )
moogal posted Tue, 03 March 2015 at 2:34 AM
They are drawn in the "foreground" color, so you could easily change that as well.  (It's the leftmost dot at the bottom-right of the display window.)
putrdude posted Tue, 03 March 2015 at 2:11 PM
So helpful thanks again.
