R_Hatch opened this issue on Mar 24, 2015 · 17 posts
R_Hatch posted Tue, 24 March 2015 at 12:20 AM
Pixar has released their free, non-commercial version of RenderMan. It's available to download here. So far, only plugins available are for Maya & KATANA. Cinema 4D and Houdini plugins are being worked on, and there are a few other programs listed as potential plugin recipients (though it's highly likely they will get made). Of course, Poser exports RenderMan format since a billion years ago, so that's not really an issue, and those of us who use Rhinoceros3D also have the fantastic RhinoMan plugin.
I'm also putting the link in the free 3d software thread, but this, being a pretty big deal, I figured warranted its own thread as well.
monkeycloud posted Tue, 24 March 2015 at 4:24 AM
Wonderful! Thanks for the heads up R_Hatch :-)
ThunderStone posted Tue, 24 March 2015 at 4:54 AM
How does one use poser with RenderMan? I'm a tad confused about where this format or what format is used with RenderMan from Poser...
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
bobbystahr posted Tue, 24 March 2015 at 9:57 AM
Yeah, woo hoo...got this yesterday in my e mail....
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Lobo3433 posted Tue, 24 March 2015 at 10:16 AM Forum Moderator
Hello ThunderStone from with in Poser Pro 2012 which is the current version I have there is an Export RIP that is the file format that RenderMan uses. It is the same format that 3Delight Renderer uses also Hope that helps
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Blender 3D Facebook Page
Miss Nancy posted Tue, 24 March 2015 at 12:41 PM
may be issues w/RIB export from PP2012/2014. haven't tried it myself.
thx fr lnk!
Lobo3433 posted Tue, 24 March 2015 at 2:18 PM Forum Moderator
thx fr lnk!
I remember there being a sort of guide or how to in the daz forum at Daz on how to export so as to render with 3Delight Render which would be similar to how to export for Poser and then rendering the Rib file with in RenderMan
Lobo3433
ThunderStone posted Tue, 24 March 2015 at 8:49 PM
Problem: It won't install if you don't have Maya... (Which I don't have). Where can I get the standalone free one if available?
Lobo3433 posted Tue, 24 March 2015 at 9:10 PM Forum Moderator
Hello ThunderStone When you run the installer it and after you put in your username and password which to run the installer you need to join the Pixar renderMan forum you will be presented with option to install the Pixar RenderMan Pro Server 19.0 and also a check box for the Maya Plugin since you do not have Maya you do not need to place a check mark in the box just check the check box for the Pixar RenderMan Pro Server 19.0 and then click next that will actually install the Stand Alone
Hope this helps
Lobo3433
ThunderStone posted Wed, 25 March 2015 at 7:56 AM
Hope this helps
I did follow all the prompts(2X) but all it did was install an empty config file in the folder labeled "RenderMan Server 19" . If it did installed the standalone then it must be invisible.... Question: does anybody have have any idea other than contacting support,at this point? ??
Miss Nancy posted Wed, 25 March 2015 at 12:22 PM
it installed after I clicked off "no maya detected" screen.
there's no app in rendermanproserver-19.0. it appears to run from command line (terminal),
but no license detected when I tried (severe error).
we don't have access to support. will try re-install.
maybe they add pixar or renderman forum here, in case anybody knows anything.
Miss Nancy posted Wed, 25 March 2015 at 2:06 PM
they said one can run it from python, perhaps from within poser, but no poser plugin. we may need to buy maya.
bobbystahr posted Wed, 25 March 2015 at 2:40 PM
Hmmm, not really free renderman then is it?
Once
I see
a sound
and
Sometimes
ThunderStone posted Wed, 25 March 2015 at 5:45 PM
What a waste of time and efforts.. I was so hoping to review RenderMan and compare it to other renderers.
If anybody ever gets it up, running,please kindly inform the rest of us non-geniuses??Thanks in advance....
Miss Nancy posted Wed, 25 March 2015 at 5:55 PM
somebody who can write python scripts may be able to help us with this.
three guys I know: snarly, BB, cage - but there are many more.
ThunderStone posted Thu, 26 March 2015 at 8:17 AM
Maybe they're at this moment working on it, eh???
ThunderStone posted Fri, 08 May 2015 at 2:03 PM
One thing to be sure... You'll need to install the RenderStudio for Maya even if you don't have Maya.. It supplies the "it" needed to visualize the rendering. I however keep getting errors on the RIB files exported from Poser. Seems there are paths that are called for the textures or material files that somehow missing even if it's in the original directory. Anybody got a clue on a work around?
