MichiCat opened this issue on Mar 25, 2015 · 16 posts
MichiCat posted Wed, 25 March 2015 at 2:31 PM
Keep your copies of Poser 10, Pro 2014 and Game Dev up to date! Download your copy of the SR5.2 update now.
If you have your notifications turned off, you can grab the update here: http://my.smithmicro.com/poser-pro-2014-updates.html
AmbientShade posted Wed, 25 March 2015 at 2:53 PM
Thanks MichiCat !
EClark1894 posted Wed, 25 March 2015 at 3:01 PM
That thing messed with my preview so much I had to trash it and go back to the previous version. I'm not saying no one else should download it, but keep your previous version safe in case you need it.
pumeco posted Wed, 25 March 2015 at 3:02 PM
Big thumbs-up to Smith Micro for continuing to put out bug-fix SR's :-)
EClark1894 posted Wed, 25 March 2015 at 5:38 PM
I didn't say it was buggy, Pumeco. In fact, I think one of the fixes was supposed to be for the preview Veiwport. What i am saying though is whatever they fixed, messed mine up.
As I'm happy with my current preview viewport, I'm just gonna stick with it.
pumeco posted Wed, 25 March 2015 at 5:44 PM
Sorry mate, it wasn't a reply to your post, I crossposted with you, didn't see your post at the time I posted :-)
I just meant in general, a big thumbs-up to them because when they add new stuff in the next release, at least the base will be more stable.
vitachick posted Thu, 26 March 2015 at 5:10 AM
My DL when I press updated still only shows SR5 which is installed..Not Sr5.2
Advise
Win10 Poser 2014/Poser 11 Daz3D
hborre posted Thu, 26 March 2015 at 8:00 AM
You need to look at the build. Yes, it will still say SR5 but the d/l button should indicate an update. ATM, I am not at my home computer to provide the latest build number.
vitachick posted Thu, 26 March 2015 at 8:02 AM
10.05.28925
Guess this is the latest?
Photopium posted Thu, 26 March 2015 at 8:33 AM
What's been fixed/changed? Thanks.
WandW posted Thu, 26 March 2015 at 1:10 PM
SR5.2 Enhancements and Fixes, by Category
Materials
Improved support for extremely large HDR textures.
Preview Rendering
Fixed preview of tangent space normal maps with strengths other than 1 (OpenGL hardware shading only).
Final Rendering
FireFly: Extreme normal map intensities now render correctly.
Figure Creation
Now storing joint blending information correctly for spherical zones when selection is ‘Replace’.
Morphing tool Create mode: Save a copy now has correct default parameter name.
Morphing tool Create mode: Object mirroring now based on selected actor rather than object under brush.
Now enabling force limits on magnet zone scale parameters of legacy content to prevent unexpected behavior stemming from allowing negative scaling.
Cloth room
Fixed case where presence of normal maps during simulation would cause instability.
Import/Export
Re-enabled import of LWO files.
Fixed case where importing 3DS file would cause instability (Mac OS X only)
"Oh - the manual says that? I have never read the manual - this must be why."rowlando posted Thu, 26 March 2015 at 6:19 PM
How can I find out what update I have installed, I use Poser Pro 2014
Cheers Rowlando
Seek what you can never loose
hborre posted Thu, 26 March 2015 at 6:28 PM
Splash screen when opening Poser will show the build.
rowlando posted Thu, 26 March 2015 at 6:37 PM
OK just tried it and it says 10.0.5 is that correct and up to date, I recently updated the via the DLC
cheers
hborre posted Thu, 26 March 2015 at 8:44 PM
10.0.5.28925
rowlando posted Thu, 26 March 2015 at 9:12 PM
Thanks yes I have that
