darquevision opened this issue on Apr 13, 2015 · 8 posts
darquevision posted Mon, 13 April 2015 at 3:37 AM
I am looking for a few bvh motions. primary i would not shooting deaths, but i will take any death. i have treid animistreet. but their files did not seem rigged for M4.
any suggestions?
Thank you in advance
parkdalegardener posted Mon, 13 April 2015 at 5:54 AM
Animistreet actually has what you want but you will have to edit the BVH files slightly. The naming conventions are not the same as Poser's naming system. Just takes a few seconds in a text editor to fix the names.
wolf359 posted Mon, 13 April 2015 at 8:36 AM
"but i will take any death. "
Hi I have some very violent deaths for V4 that will work with M4
on sale for %30 off until April 30
http://www.renderosity.com/mod/bcs/?ViewProduct=94023
Video Example
These are animated pose files that install in your poser runtim.e
markschum posted Mon, 13 April 2015 at 10:13 AM
sharecg had the carnagie mellon motion libraries available for Poser. There may be some suitable actions in there, and its free.
darquevision posted Wed, 15 April 2015 at 2:06 PM
ty. i will try this.
wolf thank you
i have used carnagie melon for other things but it didnt seen to have death. but thank you for the response.
darquevision posted Thu, 16 April 2015 at 1:51 AM
parkdalegardener:
I am going to make a quick clip with M4 then export the bvh file. I will make a copy of the bvh which needs editing and the newly made file, open them both and compare. Then I will edit the bvh file's joint names to match the ones from the bvh I made and save the newly edited file as .bvh.
Sound about right?
**Thank you again **
darquevision posted Thu, 16 April 2015 at 2:31 AM
I just tested it out. and i understand how it works! Thank you so much.
parkdalegardener posted Thu, 16 April 2015 at 7:51 AM
Sorry, I've been away. Yes you have it correct. Much easier than it sounds.
