Arah opened this issue on Apr 27, 2015 · 6 posts
Arah posted Mon, 27 April 2015 at 6:09 PM
I've recently been working on boning my own figure, however I have run into a problem.
When the hands and feet are rotated on characters such as V4, the fingers and toes move with them.
Mine however are remaining stationary, or else morphing horribly, most specifically with the Y Rotate, I can't seem to fix this in the joint zone set up.
Any thoughts on my problem?
Thanks! Arah.
markschum posted Mon, 27 April 2015 at 6:42 PM
Is your hierarchy correct ?
are you using spherical zones or the inclusion / exclusion zones ( i think they are green and red V shapes.?
Arah posted Mon, 27 April 2015 at 6:52 PM
Can I use them there? For some Reason there are no inclusion /exclusion zones, there is only the little line as you see, is there a way to add them?
primorge posted Mon, 27 April 2015 at 7:29 PM
Change the arrowed dropdown from yrotate to center... you will see the inclusion/exclusion zones then. Looks like you have a twist cursor right now.
Look at this clear tutorial
http://www.quinlor.de/tutorials/fig_setup_joints.html
Also look at PhilC's poser rigging tutorials on YouTube. Maybe your joint orders are incorrect, hard to tell...
primorge posted Mon, 27 April 2015 at 7:45 PM
Sorry, was in the middle of a test render... you should have an x and z rotate in your dropdown. This will get you the adjustment manipulators your looking for. Center is for adjusting the center position of the joints influence, the rotations are probably what your looking for. Depending on joint order.
Arah posted Mon, 27 April 2015 at 9:30 PM
ok, I think I've corrected the issue by adjusting the length of the Y rotate bar! Thank you for your Help!
