Renderholic opened this issue on May 06, 2015 · 19 posts
Renderholic posted Wed, 06 May 2015 at 4:01 AM
I had a hard drive crash and had to reload Poser 2014 and reinstall Victoria 4. I have everything loaded, but when I load a morph it does not appear under morphs in the body. You can only see it in the body part. For example: If I load hip size, before I could select the body and see all of the morphs and adjust them from there. Now I must select the hip to see the hip morph or the chest to see breast size. The problem is some morphs affect more than one body part. Full body morphs like Amazon or Fitness don't show at all. How do I fix this problem?
Renderholic posted Wed, 06 May 2015 at 4:05 AM
I forgot to add that I have all my V4 and M4 stuff in a separate runtime. However, I had it that way before and it worked.
hborre posted Wed, 06 May 2015 at 8:25 AM
Did you initialize V4 after reinstall?
Renderholic posted Wed, 06 May 2015 at 9:03 AM
No. I did not see anything asking me to do that. How do you initialize?
hborre posted Wed, 06 May 2015 at 9:50 AM
Unfortunately, it will never prompt you to do that. I am not at my own computer ATM so I am unable to give you the proper path for the file. Someone should come along soon with that information.
WandW posted Wed, 06 May 2015 at 10:59 AM
Funny; I just replied to Bruce Hoins in a discussion over at the RDNA Forum that people still had problems with EXP's 7 years on because the figure wasn't initialized, and I come and find this! :lol:
I'd post how to do it, but I can't seem to paste into the POST!!! >:( I'll try putting it in a new post...
"Oh - the manual says that? I have never read the manual - this must be why."WandW posted Wed, 06 May 2015 at 11:02 AM
You initialize the V4 figure by browsing to the 'folder you installed your stuff'/runtime/libraries/!DAZ and Click on both: (in Windows; there are Mac scripts in the same directory)
DzCreateExPFiles-V4.bat
DzCreateExPFiles-V4V3.bat
EDIT: Also do this with the .bat/.command files for M4 and his bits, too
Add this to the FAQ, Boni! :)
The Forum doesn't seem to like line feeds in pasted text..
"Oh - the manual says that? I have never read the manual - this must be why."primorge posted Wed, 06 May 2015 at 11:07 AM
Runtime/Libraries/!Daz/DzCreateExPFiles-V4.command
primorge posted Wed, 06 May 2015 at 11:08 AM
Sorry WandW, crosspost.
Renderholic posted Wed, 06 May 2015 at 3:38 PM
Thanks! I will try that as soon as I get home. I knew I could count on yall to help.
Renderholic posted Wed, 06 May 2015 at 7:49 PM
I did as instructed and morphs are working correctly with M4, but not with V4.2. Morphs still only visible in body part, not under body. Should I delete V4 and reload?
Renderholic posted Wed, 06 May 2015 at 8:03 PM
I had read on the RDNA forum that I needed to run Poser as administrator for the morphs to work. I had forgotten that, but now after selecting run as administrator it will no longer run the command files! I get message that Windows needs to know what program to use to open it. Morphs still do not work.
hborre posted Wed, 06 May 2015 at 8:47 PM
Under Windows, you should only be using the .bat files. Command format is a Mac file. I just tested the .bat under Windows 8.1 and it works fine.
WandW posted Wed, 06 May 2015 at 9:05 PM
Make sure there is only one copy of the V4 cr2 and one copy of the directory /Runtime/Libraries/!DAZ/Victoria 4/ in your Poser Library...
"Oh - the manual says that? I have never read the manual - this must be why."Renderholic posted Wed, 06 May 2015 at 9:18 PM
OK I ran the Bat files this time and they worked, but the morphs are still not loading. Do I need to restart windows? Should I delete V4 and try to reinstall?
Renderholic posted Wed, 06 May 2015 at 9:22 PM
I have only two runtimes and have a copy of V4 in each. I really only plan to use V4,2 in the second runtime. Should I delete V4 in the first runtime? I think that I also have M4 in both and morphs are now loading properly on him.
Renderholic posted Wed, 06 May 2015 at 9:23 PM
BTW I have been running the initialization bat files in the second runtime that I plan to use for all my V4/M4 stuff.
WandW posted Wed, 06 May 2015 at 9:55 PM
I have only two runtimes and have a copy of V4 in each. I really only plan to use V4,2 in the second runtime. Should I delete V4 in the first runtime?I think that I also have M4 in both and morphs are now loading properly on him.
Definitely! Make sure that there is only one copy of the morphs too; the morph packages for the Gen 4 figures need to all be in the same Runtime as the base figure.
There really should only be one copy of M4, too, but since he seems to be working properly I wouldn’t fool with him unless you have problems later.
"Oh - the manual says that? I have never read the manual - this must be why."Renderholic posted Thu, 07 May 2015 at 4:38 AM
Yea!! I deleted all the Daz People files from the first runtime, then ran the bat files in the second runtime again. Now the morphs are working. Thanks!!!!!
