Forum: Photoshop
Subject: How to restore corrupted .psd files?
9rudolf opened this issue on May 06, 2015 · 5 posts
9rudolf posted Wed, 06 May 2015 at 4:22 PM
While I was working on a PSD file in photoshop, I saved the file over after making some changes!
Is there any possibility to restore the original document using a recovery software or any other solution?
Lobo3433 posted Wed, 06 May 2015 at 4:55 PM Forum Moderator
You saved the file with changes did you already close out of Photoshop after changing the file if you had not you could have used the undo feature in Photoshop. But if closed down Photoshop I can not think of any way to revert changes after saving the file. Hopefully someone else might chime in with an answer
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Store
My Free Stuff
Facebook
Twitter
Renderosity Blender 3D Facebook Page
nedkelly posted Wed, 06 May 2015 at 7:57 PM
Have you got autosave turned on? If so it may be possible to restore a file to an earlier save point but I can't remember the method to do so, alternatively if you can access the log files you may be able to determine what changes you made and then reverse the process.
retrocity posted Wed, 06 May 2015 at 8:30 PM
The only way i've been able to "revert" after hitting SAVE instead of SAVE AS was while the file was still open going to the History palette and clicking on the entry just before the Save. but if you've saved and closed the file it's pretty well written over :(
s
marfanils055 posted Thu, 07 May 2015 at 4:42 AM
There are several methods how to try to open a corrupted AutoCAD drawing file.
·        Use the Recover command
·        Open the file and press ESC key just before Regeneration/Error message, save to DXF, load, save as DWG, Audit
·        Insert the complaining DWG as a block into an empty drawing
·        Open/save the DWG in an older version of AutoCAD or AutoCAD LT or Actrix
Or use
Photoshop Restore Toolbox from http://www.photoshop.restoretools.com/
