ypvs opened this issue on May 13, 2015 · 3 posts
ypvs posted Wed, 13 May 2015 at 12:31 PM
I've accidentally stopped the warning before deleting figures/props in Poser 10. How do I get it back?? I've had a quick check in the preference menu but couldn't find anything
Thanks in advance
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Intel Q9550 Quad Core cpu, 16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
Morkonan posted Thu, 14 May 2015 at 9:37 PM
I didn't know you could do that... :) (Note: When using a script to delete scene objects, like Scenfixer, you won't get a confirmation window unless it's specifically scripted into the script.)
If all else fails, you can delete your preferences files to remove any custom settings. Poser will rebuild them if they're not present, so it's not a big deal. You will, however, have to go reset all your customizations as it will cause Poser to build "default" preferences files. This is a handy way to clear up many weird program behavior issues that don't seem to have a logical cause, by the way.
Instructions, here : https://support.smithmicro.com/app/answers/detail/a_id/2076/~/solving-weird-issues-with-poser-by-removing-the-preferences
ypvs posted Fri, 15 May 2015 at 7:22 AM
I meant to say I accidentally ticked 'Don't show again when using the Shift+ Delete'. It has reset itself, maybe after restarting Poser which I hadn't tried earlier
