Subject: @ Snarlygribbly: Suggestion for your "Subdivider" script
pikesPit opened this issue on May 16, 2015 · 9 posts
pikesPit posted Sat, 16 May 2015 at 2:56 PM
Hello Snarly,
I post this here in the forum instead of sending you a PM, because there is a chance that other people might find the suggested change to your script useful, and might wish to use it too:
One of the great features of your SubD script is that it actually changes the geometry of a prop, so unlike the Poser native SubD I am able to use your script on - let's say a simple cube - and I can SubD it and make indents to the prop when someone is sitting on it! (think of a pouffe)
The great benefit of this (and which is the reason for my request) is that I don't even have to export/modify in external modeller/reinport a prop, but I can make subdivision (which can subsequently be deformed with the morph brush) "on the fly", just as needed in a particular scene.
Another great thing about your SubD script is that it subD's to quads instead of triangles.
This is good because Poser handles quads much better than triangles, but it's even better when you subdivide above-mentioned cube: it gives you far better deformability than you can ever achieve by simply triangulating.
To be precise, your script is not just good, it's simply great!
Now, to my request:
The only way (afaik) to make the subD stick is to start a render, then abort it to go back to the preview and have the subD'ed prop in the scene for further morphing. (make sure that "Undo after render" is UN-checked!)
Only thing left to do is to delete the original prop, and eventually reparent the subD'ed prop.
SUGGESTION:
Why not add the subD *without" the need to launch a render?
Add another button to the script "Subdivide without rendering", and maybe even an option "delete old prop" instead of just making it invisible.
(Basically it would be the same function as "render", just without the "render" part)
Maybe some other people might find this useful too because we ever so often run into a sofa which consists of "bricks", and your script is a great way to add geometry to deform it!
And all that without the hassle of exporting/using a modeller/importing/noticing that something went wrong/etc. etc. asf.
Just by using Poser, and your script...
Peter
moriador posted Sun, 17 May 2015 at 2:18 AM
I've been using the script a lot lately to increase resolution of dynamic clothes after the sim. It's perfect for it. (In fact, I like the results so much that I think it should be an integrated option in the cloth room.) Anyway, you don't have to start a render. Just...
  1. select your prop using hierarchy editor or your cursor in the preview
  2. set subdivide to the level you want
  3. uncheck "undo after render"
  4. decide whether you want to keep edges or not and check box if needed
  5. press the "subdivide" button
Prop then appears on top of old prop. Old prop is invisible. New prop is visible. No render needed.
pikesPit posted Sun, 17 May 2015 at 2:59 AM
The Subdivide Button!
Duh! That is all I was asking for. I didn't realize it's a button, and now I feel rather goofy.
Thanks for pointing this out moriador!
Peter
moriador posted Sun, 17 May 2015 at 4:07 AM
LOL. I know what you mean. I live in goofyland. :) It's great to see that other people really like and use this script, though. Now if only there were an equally simple way to reduce polys and still keep them as quads... :)
smallspace posted Wed, 03 June 2015 at 11:14 AM
Does this script work with Game Dev? I can see it on the "Window:Addons" menu, but I don't see any way to activate it. The lack of documentation leaves me clueless as to how it's supposed to work. Can anyone give me a step my step as to what I'm suppose to see and do?
I'd rather stay in my lane than lay in my stain!
parkdalegardener posted Thu, 04 June 2015 at 6:32 AM
As a heads up, snarly no longer has an account here. He won't see the thread and won't get PMs. He still actively supports his scripts. In fact I am testing his rework of Particles3 right now. It should be released in the next 24 hours if there are no more issues reported. He is active on another major site but I do not know if I can name the site without breaking the rules here.
FrankT posted Thu, 04 June 2015 at 2:38 PM
name it but don't link it?
My Freebies
Buy stuff on RedBubble
wimvdb posted Thu, 04 June 2015 at 3:49 PM
Public beta is now available at http://forum.runtimedna.com/showthread.php?99030-Particles-for-Poser
moogal posted Fri, 05 June 2015 at 3:21 PM
I thought there was only one unmentionable site...  Surely you can mention the "official" Poser forum here, right?
