Subject: simple dots question
coelacanthropy opened this issue on May 24, 2015 · 9 posts
coelacanthropy posted Sun, 24 May 2015 at 10:36 AM
There was a time when I knew how to do this but ...
How do you clear out the camera dots in Poser 9? I thought there was a way to do it through the user interface and also by locating the folder and manually deleting the dots, but it seems I've forgotten.
Thanks
heddheld posted Sun, 24 May 2015 at 11:08 AM
alt click on pc maybe dif on mac
coelacanthropy posted Sun, 24 May 2015 at 11:25 AM
That did the trick. Thanks!
jamminwolf posted Mon, 25 May 2015 at 3:37 AM
Were you talking about the UI dots?  No clue what they're for.
heddheld posted Mon, 25 May 2015 at 5:34 AM
ui dots save your ui layout, if you use dif layouts for dif jobs there useful, the cam and pose dots are more then useful there great !!
jamminwolf posted Mon, 25 May 2015 at 1:30 PM
Oh, ok, pretty much the same as using frames for poses & camera angles, as well as doing dynamic clothing), which I use all the time, so that pretty much makes the UI dots useless, unless there's something I'm missing?
willyb53 posted Mon, 25 May 2015 at 3:17 PM
UI dots can save your sanity :D
Always set up at least one for your default set up.   If you accidently move a window off screen, (library for example) a single click will restore it, compared to going back to the default and starting from scratch.
Bill
People that know everything by definition can not learn anything
jamminwolf posted Mon, 25 May 2015 at 4:04 PM
Bill
Ok, so basically it's not only for poses/camera location on the scene, but rather for the window (display, camera, lights, library, etc...) as well?  I've never moved a window off my screen, though it could happen, but that's pretty useful for people who do make that mistake often.
RedPhantom posted Mon, 25 May 2015 at 5:46 PM Site Admin
The ui dots are for your whole user interface. It's not just good for if you push a window off screen, it's good for if you accidently drag and dock a window to the wrong location and make your scene window microscopic. Or say you sometimes need the scene, cameras and parameters open while other times you want the scene, lights and animation. You can change it with a simple click saving you screen space. I usually use two monitors and have some windows on the second monitor but sometimes I want to watch a video while posering. I have one dot just to move all windows to the main screen.
