Subject: Could I get some help?
arrow1 opened this issue on Jul 16, 2015 · 10 posts
arrow1 posted Thu, 16 July 2015 at 10:22 PM
file_65b9eea6e1cc6bb9f0cd2a47751a186f.jpI have been user Poser since version 4.However I have never learned to make a prop from Poser Primitives. I have four poser primitives that I have put together as a prop and I want the different primitives to be separate items for materials.
  1. How do I bring all these items together as one prop but not making one whole obj. I want separate parts for the materials.
  2. Do I need to UV map this item for separate materials? If so how do I create a UV map?
I am not very good at reading lots of tutorials. A simple step by step would be appreciated. Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
EldritchCellar posted Thu, 16 July 2015 at 10:54 PM
Ok.
File/export: wavefront object/ single frame. Click the universe box, all objects will then be deselected in the heirarchy. Click each box corresponding to each primitive that comprises your prop so that each has an x, you want only those objects with an x. Click ok. Make sure all options are unchecked except for 'include existing groups in polygon groups'. Click ok. Name your object and save to wherever is convenient.
Delete or hide your original objects. File/ Import: Wavefront Object, uncheck all options. Find your file, click Open. Your prop is now one object with 3 groups named according to their comprising primitives, accessible and editable via the grouping tool. It also has a single material per comprising group named preview:1, preview:2, etc.
Do you have wings3d?
W10 Pro, HP Envy X360 Laptop, Intel Core i7-10510U, NVIDIA GeForce MX250, Intel UHD, 16 GB DDR4-2400 SDRAM, 1 TB PCIe NVMe M.2 SSD
Mudbox 2022, Adobe PS CC, Poser Pro 11.3, Blender 2.9, Wings3D 2.2.5
My Freestuff and Gallery at ShareCG
EldritchCellar posted Thu, 16 July 2015 at 11:07 PM
You don't need to uv map if you just want separate materials, only if you want to have image file based textures that behave according to your specifications. Poser props are already uv mapped (sorta ;)). You can apply a patterned image map, like a grid pattern, to the box primitive for example and it will look like a box with grid lines.
Edit_ looking again at your construction I see that it is made of 4 primitives, so you'll have 4 groups and 4 materials (I said 3 earlier).
EldritchCellar posted Thu, 16 July 2015 at 11:17 PM
Have you met Dr.Geep? Lol.
EldritchCellar posted Thu, 16 July 2015 at 11:38 PM
Another method;
Go to window, heirarchy editor. Open the hierarchy editor. In the listing drag and drop each little ball icon corresponding to a prop/part onto a single part of the prop. Each will be parented to that single part as children (you can also create more complex parent/children/grandchildren etc hierarchies). Now your construction is still comprised of it's separate parts/groups, has 4 materials. It must be manipulated from the parent part in the workspace however, otherwise it will pull apart.
In the very simplest sense, using this method of parenting and establishing a hierarchy with multiple groups, you will have created the beginnings of a rudimentary figure. It just doesn't have any bones to hold it together.
If you wish to save your new prop, with method 1 save to prop libraries as normal. With the parenting method, use the select subset option. Choosing your parts. It will load with the parent child relations intact.
EldritchCellar posted Thu, 16 July 2015 at 11:58 PM
Hmmm, couldn't seem to figure out how I was wanting to spell hierarchy in the above posts.
Hope I helped, arrow1.
markschum posted Fri, 17 July 2015 at 12:01 AM
when you export an obj, the file will contain the material names, look for lines usemtl xxxxxxx    where xxxx is the material name. you can rename these in the obj file, save it and import to poser with the new material names.
if you parent the prop you can use the heirarchy editor to create it as a figure. You may need to clean up the pivot points (centers) depending on how it bends.
EldritchCellar posted Fri, 17 July 2015 at 10:33 AM
What Markschum said, you can also rename your groups in such a fashion by finding the 'g' blocks of text, located directly above the usemtl lines.
If you've saved your prop to the library, common practice is to strip out the embedded .obj and insert a file path reference to an .obj in your Geometries folder. This is easy to do in a text editor but there are some utilities to automate the process. Here's a classic free one_
http://www.vanishingpoint.biz/freeitemdetail.asp?FreeItemID=421
arrow1 posted Fri, 17 July 2015 at 8:15 PM
Many, Many, thanks everyone. I new I could rely on the Poser forum for help! Cheers
EldritchCellar posted Fri, 17 July 2015 at 8:29 PM
Glad to help, arrow1.
