ElZagna opened this issue on Aug 18, 2015 ยท 3 posts
ElZagna posted Tue, 18 August 2015 at 5:19 PM
I've used FC2Fix to clean up my expressions and it has worked like a charm. I tried it today and it doesn't work. It loads just fine and the interface behaves like it should, but nothing gets changed. This is the first time I've used it with Windows 10, so perhaps that's the problem. It's a standalone executable, so the version of Poser shouldn't matter. It's written by Gary Sayers, if that helps.
Alternatively, is there another way to "clean up" expressions? Let me explain what I mean by "clean up" an expression. When you save an expression with Poser, it not only saves the expression morphs (smile, eyebrow up, etc.) but it also saves the face morphs (George, Old, BrowHeavy, etc.) as well, so when you try to reuse the .fc2 file later on it tends to set the face back to the V4 default. FC2Fix.exe simply removes the non-expression morphs from the file.
OS: Windows 10 64-bit, Poser: 10
