DarkElegance opened this issue on Aug 21, 2015 ยท 6 posts
DarkElegance posted Fri, 21 August 2015 at 12:43 PM
Ok I made this pillar thing with drapes....but I was hoping to mirror it on either side of the scene. Now I thought there was a way to mirror an object in DS...but I cant find a way to do it.
Any suggestions?
https://www.darkelegance.co.uk/
cunningf posted Fri, 21 August 2015 at 1:40 PM
If you use New Node Instance in the Create menun it makes an exact copy of the selected item which can then be moved wherever it's needed.
DarkElegance posted Fri, 21 August 2015 at 1:41 PM
cunningf posted Fri, 21 August 2015 at 1:45 PM
Does setting the X & Z scale to -100% do it?
If not I'm out of ideas.
RHaseltine posted Fri, 21 August 2015 at 2:58 PM
Only set one axis to -100% - setting two axes to -100% is the same as a rotation around the third axis.
malwat posted Sat, 22 August 2015 at 5:08 PM
Not sure whether it will do what you want, but look at http://docs.daz3d.com/doku.php/artzone/pub/software/symmetry/start
Alternatiely copy the item as suggested above and change the horizontal scale (probably the X-scale) to -100% as suggested by cunningf
I am assuming DS rather than Poser....
Malwat
Getting younger by the day; getting older by the minute....
