Subject: Maternity
mdbruffy opened this issue on Aug 26, 2015 ยท 13 posts
mdbruffy posted Wed, 26 August 2015 at 4:15 PM
I have a character in my next graphic novel that's nearly nine months pregnant and based on V3. I am having a hard time finding ANY maternity outfits or anything that would pass for a maternity outfit. Do such outfits exist? If so. where?
hopeandlove posted Wed, 26 August 2015 at 4:20 PM
Hi-- This is the Community forum.
Which forum were you wanting to post in?
Hope Kumor
Editor-in-chief of Renderosity Magazine
mdbruffy posted Wed, 26 August 2015 at 4:54 PM
I just created the thread. I'm looking for this type of outfit. If you want to move the thread, fine, just let me know where it goes.
hopeandlove posted Wed, 26 August 2015 at 4:55 PM
This has been moved to the Poser thread now.
Thanks!
Hope Kumor
hborre posted Wed, 26 August 2015 at 5:41 PM
I think you're out of luck on this one. I haven't seen any maternity outfits for any of the current models. You might get away with using dynamic clothing, however the mesh could stretch out making any texturing nearly impossible. Sub-D could alleviate this situation.
mdbruffy posted Thu, 27 August 2015 at 8:28 AM
I did find one site with an outfit- Renderotica of all places.P-ei_v4maternitypromo1-04.jpg
I don't know if the forum will allow a link, so I won't post one.
hborre posted Thu, 27 August 2015 at 8:37 AM
Right, no links allowed. Especially there.
mdbruffy posted Thu, 27 August 2015 at 8:44 AM
hborre posted at 8:44AM Thu, 27 August 2015 - #4224634
Okay. No problem.
Morkonan posted Thu, 27 August 2015 at 10:55 PM
mdbruffy posted at 10:51PM Thu, 27 August 2015 - #4224630
I did find one site with an outfit..
You also have four options that can help you create a maternity outfit from just about anything.
  1. Use magnets on the relevant portions of the clothing.
  2. Use Poser's Morph Tool on the clothing. (A bit more difficult since it is difficult to do precise work.)
  3. Use Poser, depending upon the version you have, to transfer the "Pregnant" morph to the clothing. (I think you can start doing that in Poser 10? Not sure.)
  4. Use an outside program like Morphing Clothes to transfer the morphs from the figure to the clothing. (I recommend starting with this option and then using magnets/morph tool to fine tune if you can't get exact results.)
mdbruffy posted Fri, 28 August 2015 at 7:13 AM
I have never used magnets. I'll be going with the outfit I found pictured above. Thanks, though.
Boni posted Sat, 29 August 2015 at 3:28 PM
Many of V3 clothing from Daz have pregnant morphs including the morphing fantasy dress which can be altered to appear like a maternity dress fairly easily. Not at my work machine so I can't verify.
Boni
Boni
mdbruffy posted Sat, 29 August 2015 at 3:55 PM
Yes, it does. But the way it's shaped,looks more like it was vacu-formed around her body. That's not the look I wanted.
Boni posted Sat, 29 August 2015 at 6:25 PM
Another suggestion could be tweaking a dynamic garment ... I have discovered that some cloth items will expand past the original mesh parameters. A higher poly-count helps as well. Just a thought.
Boni
Boni
