Forum: DAZ|Studio
Subject: My Library on another Drive
arrow1 opened this issue on Aug 26, 2015 ยท 9 posts
arrow1 posted Wed, 26 August 2015 at 5:35 PM
My C:/ Drive is nearly full.Can I create a DAZ My Library on an external removal hard drive? If so can anyone assist me me with what I have to do to make Studio reconize it? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
3doutlaw posted Wed, 26 August 2015 at 6:50 PM
Thats what I do. Works Fine. Make a Content directory and move stuff over, then add that content directory to daz, you can have more than one, so you can have stuff in both if you want to set it up, move a few things and try it. You can even have duplicate stuff in both. (I wouldnt make that a practice, but it would allow it)
arrow1 posted Wed, 26 August 2015 at 7:17 PM
Many thanks for your help! Cheers
arrow1 posted Sun, 30 August 2015 at 10:05 PM
I have another similar question. Can I change the DIM Manager to install into My Library on an external removable hard drive? It is still putting all my downloads in my C:/ users,public documents. As I mentioned before this drive is almost full! Cheers
Magic_Man posted Mon, 31 August 2015 at 6:21 AM
Yes, just update the appropriate file path in the DIM manager to install to the new library location.
bhoins posted Thu, 03 September 2015 at 9:18 AM
Two minor points.
If you are mapping to an external drive, and that drive is not connected, issues may occur.
If you are mapped to a drive that is completely full, issues will occur, this is especially true of the C: drive.
One additional point. Mapping your content to another drive is a typical thing to do. What many people don't realize is that you can map your temporary directories to a different drive. This is extremely effective if you map them to a high speed SSD. (High speed 64 GB and 128GB drives are getting to the pretty cheap price point.)
It is under preferences and there are two of them.
Grum posted Thu, 10 September 2015 at 12:29 AM
Hi All. Are you saying that I can create separate Contents folders, and somehow tell Daz3d to load them when I need them. Rather like Runtimes in Poser? Reference to the Temp Directories, where are they normally? And how do I move them? Grum
AllThatxAz posted Thu, 10 September 2015 at 1:26 AM
Hi Grum,
As I understand, it's something like that. However, it's not really "Contents folders". There is a "Content Directory Manager" under Edit.Preferences. Maybe you already knew about it, though. I don't know how "Runtimes in Poser" work.
If your question is really about "what is loaded in memory", I don't know the answer. I think DAZ Studio builds an index of your content, but it really seems to only load the asset when you put it in the scene.
It appears DAZ Studio creates its own temp files in the AppData folder on the system drive, or at least whatever the system understands is %AppData%. I think to move these, you'd have to move %AppData%, which I think only Windows surgeons should do.
Personally, I created about 6-10 different directories with the Content Directory Manager, because I can think of different scenarios that I would want some available. Also, I factor out new directories for different marketplaces. DAZ content installs fine for me 99% of the time, but content from other marketplaces sometimes needs some kind of fixup, which I'm still learning how to do.
Hope this helps
Grum posted at 11:09PM Wed, 09 September 2015 - #4227480
bhoins posted Thu, 10 September 2015 at 9:04 AM
Grum posted at 8:03AM Thu, 10 September 2015 - #4227480
Yes you can. Right Click on the COntent Library tab and choose Content Directory manager.
Temp file location is in Preferences. (Normally in the shared documents folder, wherever you have that mapped.)
