atpo opened this issue on Sep 15, 2015 ยท 4 posts
atpo posted Tue, 15 September 2015 at 6:32 PM
So long time no meeting here. how's everthing going?
1:only just import obj that fits
well 2:but after transfer utility,that fits
badly on left-hand. 3:does check in dialogue is
wrong? 4:what is the right way to check
in transfer utility when it is for
g3? 5:Does need setup room that can
do fit well? Any setup room tutorial is where? Thanks
cedarwolf posted Wed, 16 September 2015 at 10:28 AM
Interesting...I'll have to keep an eye on this thread
hborre posted Wed, 16 September 2015 at 11:23 AM
I am assuming that you are trying to transfer rigging from G3F (please use the proper naming to avoid confusion) to a custom made dress. Or does the dress belong to another figure? Judging from the panel settings, I would uncheck the Face Groups, you really don't need it with the dress. Take a look at Content Type at the bottom and see if there is a selection for appropriate for the clothing. Otherwise leave it blank. After rigging transfer, save the dress to your library, delete it from the scene, then reload it it G3F. Allow autofit to dress the figure. If it doesn't fit, check if there are any active morphs causing poke through. Those might need to be transferred also.
atpo posted Sat, 19 September 2015 at 8:48 PM
thanks I do try again.
