Forum: DAZ|Studio
Subject: Problems with saving Poser content for Daz Studio
ICRDesign opened this issue on Sep 18, 2015 ยท 7 posts
ICRDesign posted Fri, 18 September 2015 at 6:06 AM
Hi all,
I am Poser user, but I would like that daz studio user could use my items. The question is: does anyone know tutorials or have ideas how to work this out?
All my attempts produces issues: files not found, assets not read etc....
I explain what I do:
  1. import a poser prop to daz studio (that is working well)
  2. I select the item and save it as prop asset (this is working for one item, but not for several selected)
  3. Test: the items don't go in place, there are assets not found. I can't find a tutorial which explains all the processus or what I have to do exactly.
Could you help me ???? Irene
LPR001 posted Fri, 18 September 2015 at 6:39 AM
Hi Irene When you go to load a prop do you get a pop up saying "Can't find missing items make sure your path to Poser is set up correctly" with a locate button ? usually it is looking for a jpg?
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
ICRDesign posted Fri, 18 September 2015 at 6:48 AM
No, it is usualy searching for an asset which is in the right directory and present
LPR001 posted Fri, 18 September 2015 at 6:52 AM
I know that some older Poser props/content can be missing companion files for Daz I will see if I can dig up a tutorial for you I have someone in mind if you look through her vids I am sure you will get the answers you seek and a good guide to follow :-)
- Johnny G
LPR001 posted Fri, 18 September 2015 at 7:05 AM
Sent u sitemail hope it helps :-)
- Johnny G
ICRDesign posted Fri, 18 September 2015 at 7:15 AM
Thank you so much !!!
RHaseltine posted Fri, 18 September 2015 at 3:44 PM
A simpler option may be to save new materials presets for the items and have the user apply those. Especially if you have mat files (in the Poser Pose or Materials library) anyway - just give the DS files exactly the same name as the equivalent Poser setting and drop the .duf in the same folder (discarding the .png); DS will then use them instead of the Poser file (of course this does assume you are creating custom materials for DS).
