goofygrape opened this issue on Oct 18, 2015 · 5 posts
goofygrape posted Sun, 18 October 2015 at 3:03 PM
please tell me how to use the shader's for daz studio 3delight and for iray ,I have a lot of them don't know how to impalement them. very confused to say the least :(
RHaseltine posted Sun, 18 October 2015 at 3:13 PM
You are using shaders every tiem you render. If you mean Shader Presets, you need to select the item you wish to apply them to and the surface on the item, then double-click the preset; usually this is easiest to do in one click with the Surface Selection tool (the potential issues are where the surface you want is underneath another, as with the inner parts of the eye - for those you need to select the model and then get the surface selected via the list on the left of the Surfaces pane, in its Editor tab).
The Surfaces pane (Window>Panes(Tabs)>Surface) is where you manually adjust the settings for the applied shader (Editor tab) or you can also use it to apply presets (Presets tab)..
goofygrape posted Sun, 18 October 2015 at 4:13 PM
thanks I only want to apply some times such as a shader for a rock or sifi texture Surface selection tool? does that go for iray rendering also ?
wheatpenny posted Sun, 18 October 2015 at 4:23 PM Site Admin
To apply a shader to a rock, just select the rock and double-click on the shader.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
goofygrape posted Sun, 18 October 2015 at 4:48 PM
thanks guy's I'm going to do this now . John
