ThreeDeeArt opened this issue on Oct 31, 2015 ยท 3 posts
ThreeDeeArt posted Sat, 31 October 2015 at 10:24 AM
I have a problem with opening a PZ3 figure in Vue and it has not retained the pose and has reset to the default pose Is there a way to over come this?
estherau posted Tue, 03 November 2015 at 5:24 AM
Is the figure a genesis? Because PZ3s with genesis have some problems. If it is genesis, turn subd off completely using the python script. If it is a V4 or something then maybe check vue preferences, check that you have the 2013 SDK selected (you will need a restart if you change it), and also check you are importing the correct frame. I think vue calls the poser frame one, frame zero or something. Also when you import the pz3 set the bump to -.008 Love esther
cyberknight1133 posted Mon, 30 November 2015 at 11:18 AM
I've been avoiding the genesis stuff completely, assuming that it wouldn't import correctly into Vue. Am I understanding you correctly in that you can if you turn off subdiv?
