Forum: Photoshop
Subject: Creating an Action
3dsolo opened this issue on Jan 04, 2016 ยท 8 posts
3dsolo posted Mon, 04 January 2016 at 9:34 AM
Hello, I have PSD files that contain dozens of screen captured images in each one. Is there a way where I can create an ACTION that will:
  1. flatten the PSD
  2. Save the file as a JPG #1
  3. unflatten
  4. chose the next layer and flatten 6 save the new as image #2
  5. repeat this for the next 9 layers. Leaving me with 10 individual JEPGs
thanks
Lobo3433 posted Mon, 04 January 2016 at 12:52 PM Forum Moderator
Hello 3dsolo
I am not sure if what you are attempting will work as an action all I can give you is the steps on how actions are created. I do not see that it wouldn't be possible but you would have to go thru all the steps in recording one and seeing if it will work https://helpx.adobe.com/photoshop/using/creating-actions.html
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Store
My Free Stuff
Facebook
Twitter
Renderosity Blender 3D Facebook Page
Wolfenshire posted Mon, 04 January 2016 at 4:57 PM Online Now! Site Admin
Hi, Yes, you can create the action you are talking about. You'll have to run through the entire recording once on all the images with unique file names. And you would have to ensure the directory you choose is empty of the previous batch each time. It would take awhile to get it right, but yes, can be done. You could set it up to do a thousand images if you really wanted. The record actions is found in on the pallet menu. You could also check on deviant, someone might have already made that action, but then again, even the smallest deviation from the original and it goes all wonky, so, best to make your own.
(on a side note: I made a quick action to test it, and it did work)
Wolfenshire, Moderator/Community Leader
Lobo3433 posted Mon, 04 January 2016 at 7:45 PM Forum Moderator
Thanks for sharing Robert I wasn't to sure if it could be done have only ever created one action myself back in CS 3 and then it wouldnt work in CS 5 never redone it since the action became obsolete for the purpose I created it for in the first place.
Lobo3433
Renderosity Store
My Free Stuff
Facebook
Twitter
Wolfenshire posted Mon, 04 January 2016 at 8:37 PM Online Now! Site Admin
You are correct, in the earlier versions of CS there were commands (like 'save') that you couldn't use in an action. In CC 2015.0.0 the save is working in actions. I upgraded to CC 2015.0.1, but oh was that a nightmare... hated it and rolled it back. (the darn paintbucket tool was missing). Why would they take away the paintbucket, it's one of my most used tools.
yomah posted Tue, 05 January 2016 at 8:43 AM
You can try and use the Export Layer to Files option built into PS located under the File menu. You get a dialog box that will let you choose if you want just the visible layers only, choose the file type/format and where you want to put them. It is a whole lot easier than creating and running an action a bunch of times.
~yO
3dsolo posted Tue, 05 January 2016 at 6:42 PM
Thanks, I'll try that
arrow1 posted Tue, 12 January 2016 at 8:12 PM
I regularly create actions and batch process them.First click on the create new action symbol at the bottom of the actions palette.I give the action a name and also a function key.Hit record.Then create your action.Crop, re size,enhance etc and flatten image or whatever action you want to create.When finished hit stop recording and save your action.If I have lots of images I want to enhance crop etc all the same I put them into a folder.I then go to File Automate and Batch if I have saved as a set I go the set action in default actions,then to Action and select the action I want.Go to source,Folder or if you have your images open on the screen then go to folder where you have saved your files for processing and click the action.All your images will be saved and enhanced. Hope this might help.I had to process over a 150 images from a yacht Race recently.I was lucky as the all the lighting and exposures were the same so I made an action.It saved me many hours of work.Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
