ThreeDeeArt opened this issue on Jan 08, 2016 ยท 7 posts
ThreeDeeArt posted Fri, 08 January 2016 at 9:50 AM
I have Poser 11 and I have loaded GND Anastasia athletic but for some reason the skin textures will not load. When I looking the material folder the files are .mc6 I tried loading these through the material lab but did not work. The morphs and poses are working fine so at the min I am stuck with the default V4 texture
Any help will be appreciated
hopeandlove posted Fri, 08 January 2016 at 10:16 AM
Hi @ThreeDeeArt-- I'm going to move this to the Poser forum so members can better assist you! Thank you so much for asking, what a great question!
Hope Kumor
Editor-in-chief of Renderosity Magazine
ThreeDeeArt posted Fri, 08 January 2016 at 11:15 AM
Thank you :D
JohnDoe641 posted Fri, 08 January 2016 at 11:37 AM
GND Anastasia is for Alyson2 not V4.
Did someone make v4 GND product called Anastasia, because that would be really confusing.
hborre posted Fri, 08 January 2016 at 12:30 PM
AFAIK, GND Anastasia is definitely for Alyson 2. The only one for Victoria 4 is The Girl Next Door 4: Athletic. There should be no reason why the textures are not loading.
bantha posted Fri, 08 January 2016 at 1:35 PM
If you try to load GND Anastasia's textures to V4 (GND 4: Athletic) you won't see much because the material zones are different. Did you get an requester if the missing materials should be generated? If yes, you try the wrong material set for the figure.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Blackhearted posted Fri, 08 January 2016 at 2:11 PM
Hi there,
Anastasia is for the Poser default figure, Alyson 2. AFAIK she ships with Poser 11 as well.
GND4.2 is the one for Vicky 4.
Currently most of the older crop of textures/shaders dont work properly with the new Superfly renderer, so GND4 and Anastasia owners should just render her in the Firefly renderer for now.
I'll likely update both in the coming weeks.
