tsarist opened this issue on Jan 21, 2016 ยท 9 posts
tsarist posted Thu, 21 January 2016 at 3:06 PM Online Now!
Carrara is on sale today only! For anyone who wants to upgrade to 8.5Pro is going for $65 ALL other Carrara items "over there" are 1/2 off.
Today Only!
EddyMI posted Thu, 21 January 2016 at 3:26 PM
A new version I would prefer way much more
Live Long and Prosper
headwax. posted Thu, 21 January 2016 at 5:12 PM
thanks Tsarist for the heads up
dr_bernie posted Thu, 21 January 2016 at 9:52 PM
A new conspiracy by Daz3D to make us believe that Carrara 9 is on its way and that Carrara is still worth buying!
Moonglow posted Fri, 22 January 2016 at 1:24 AM
The latest four products released by DAZ3D will NOT WORK WITH CARRARA, nor will most future releases by DAZ3D. Read their latest FAQs and their forums about the new DRM products and Carrara incompatibility. Also, if you run "Daz Connect" feature in the new DAZStudio 4.9, it will, depending on file locations, update current DAZ product files in your runtimes and render them unusable in Carrara. Read ALL the FAQs...and also "between" the Daz3D lines.
Mythic3D posted Fri, 22 January 2016 at 5:49 AM
Moonglow posted at 5:44AM Fri, 22 January 2016 - #4250585
That's partly true. The four new items will not work in Carrara, but not all future items will be DAZ Connect-only (yet - eventually they will be, you're right about that, but they are not switching over entirely right away). Running DAZ Connect and allowing it to download content updates WILL download versions Carrara cannot use, but it WILL NOT over-write any content you have already downloaded/installed except for earlier versions of D/S itself. The new encrypted files it downloads go to a different location and are in a different file format. I installed it just to take a look and it only needs to connect using DAZ Connect one time and then never again (currently).
Even if you install D/S 4.9 you only have to let Connect connect once and then you never have to use it again (currently) and they have said repeatedly that all the old products that came out pre-4.9 will always still be available in your library as .zip files.
tsarist posted Fri, 22 January 2016 at 8:31 PM Online Now!
Thanks for the warning Moonglow and for the clarification MDO.
We will have to keep an eye on that issue going forward.
P.S. The sale is extended through this weekend for PC Club members.
galaxiefilm posted Mon, 25 January 2016 at 5:00 PM
Further evidence that someone needs to wrestle Carrara away from DAZ.
0oseven posted Thu, 28 January 2016 at 8:58 PM
I hope Carrara doesn't go the way of "Antics" - an animation program available a few years ago. We were lured into upgrading to professional at a cheap price. A few months later it was announced Antics would no longer be supported and the site shut down. However I don't believe Daz would go that far with Carrara would they ? -- Would they ??
