Subject: Grouping all the parts to a prop
stevenmeyer6464 opened this issue on Feb 01, 2016 ยท 4 posts
stevenmeyer6464 posted Mon, 01 February 2016 at 10:08 PM
HI, I am using Poser 11 pro and have a prop (tiny car) and when the prop loads there are a lot of separate pieces. What I mean by separate pieces when you go to select it to move it or "morph it" there is not just on item (tine car) but at least 12 different parts of the "tiny car". I can live with that if all I wanted was just one car but I would like to have several cars. I have also made changes and would like to have all the same changes in all the cars, but I do not want to be constantly making the same changes over and over again. Is there some way I can group all the parts and then copy and past the group? Thank you
3D-Mobster posted Tue, 02 February 2016 at 12:04 AM
Not sure this is what you mean so in case its not you can ignore it :D
But you could use the hieraki editor to link all parts to the main part for instant. Make the changes you need and then save the car to your library. Then you should be able to simply add the car again from the library and it will have the same features as the other one.
Another way is when you have imported your car and you have all the different parts etc. Make all the changes you need and then export it again as an OBJ including all the parts and then import that one again. In that case the model will be 1 obj with the changes you made before you exported it. You might have to set up materials again though, but im pretty sure it will maintain them, but anyway just beware that you might have to fix them again.
EldritchCellar posted Tue, 02 February 2016 at 12:46 AM
Agree with 3d mobster in both recommendations.
W10 Pro, HP Envy X360 Laptop, Intel Core i7-10510U, NVIDIA GeForce MX250, Intel UHD, 16 GB DDR4-2400 SDRAM, 1 TB PCIe NVMe M.2 SSD
Mudbox 2022, Adobe PS CC, Poser Pro 11.3, Blender 2.9, Wings3D 2.2.5
My Freestuff and Gallery at ShareCG
stevenmeyer6464 posted Tue, 02 February 2016 at 7:21 PM
Thanks I'll try those suggestions.
