Subject: Lock selection in Poser?
gojira-kun opened this issue on Apr 15, 2016 ยท 3 posts
gojira-kun posted Fri, 15 April 2016 at 12:05 PM Online Now!
I'm learning Poser 10. It drives me crazy when I try to manipulate a figure directly. I select a foreground leg but when I move it I discover Poser has selected a pinky hidden in the background instead. Is there some way to lock a selection so I adjust only the part I want? Not the "lock figure" command. That prevents your making any changes at all. In school we worked with 3DS Max. I liked the way you could tap the space bar to lock and unlock a selection. Is there something like this in Poser?
nerd posted Fri, 15 April 2016 at 12:48 PM Forum Moderator
Hold down the shift key and it will keep it from selecting a different body part when you click.
gojira-kun posted Fri, 15 April 2016 at 1:48 PM Online Now!
Solved! That bit with the shift key is exactly what I was looking for. Thanks!
